Go to Post Look guys, I am telling you for the fourth time - you are NEVER going to earn your official "Geek" certificates if you keep spelling "pwned" with an "O" in it! - dlavery [more]
Unread 19-09-2013, 00:36
paper: Drivetrain Acceleration Model
Thread created automatically to discuss a document in CD-Media.
Drivetrain Acceleration Model by Ether
Unread 19-09-2013, 00:42
Joining the 900 Meme Team
FRC #0079
Re: paper: Drivetrain Acceleration Model
Very cool. Now if only we could convince you to use variable names longer than 2 characters
Am I correct in assuming that Tm = Ts*(1-V/Vfree); on line 55 could also be used to figure out approximate current draw? Or am I over simplifying this?
Unread 19-09-2013, 01:19
Yes. Kt, the motor torque constant, is Newton_meters per amp. So you can calculate the motor amps A=Tm/Kt*. For a CIM, Kt≈0.018 Nm/A. You could modify the C code to output amps so it could be plotted.
However, the model does not account for voltage drops due to heavy currents through the wires, the wire connection points, the battery' s internal resistance, changes in motor resistance due to temperature, etc so the accuracy of Tm (and the current) will be affected. Also, Kt is not strictly constant - it varies somewhat with motor temperature.
I've been programming since 1969 and I've never liked long variable names. To me it makes the code much less readable. I like the code to look like the way I would write the equations. I know opinions differ on this matter.
* when not slipping. when slipping, you'd have to use the kinetic friction force and back-calculate the motor torque.
Unread 19-09-2013, 01:47
FRC #0079
Yes. Kt, the motor torque constant, is Newton_meters per amp. So you can calculate the motor amps A=Tm/Kt. For a CIM, Kt≈0.018 Nm/A. You could easily modify the C code to output amps so it could be plotted.
So, close enough for determining if it's bad or not but not close enough to be an "accurate model".
Twas just a joke, I know the equations look like this but I've always found annotating them with english names helped me understand what was going on. Course, that was the second thing I did with this (first was read what heun integration was). Thanks for sharing this.
Unread 19-09-2013, 10:28
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
This is cool. I wouldn't have looked up Heun's method if I hadn't seen this thing. I also wouldn't have looked up rolling resistance. This white paper has given me some homework. Hopefully I can include those two things into the calculator I've been playing with. Thanks very much for posting goodies like this.
Unread 19-09-2013, 11:36
I posted an update/correction to the C code:
- fixed an error in the English-to-SI conversion constants
- modified the accel function to better reflect the relationship between friction and rolling resistance
- added total drive motor amps to output
Unread 19-09-2013, 12:49
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Can't look at this in-depth right now... but thank you very much for another great resource! This looks quite useful... particularly if k1, k2, and k3 are given real, semi-accurate values (not just assumptions)!
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 19-09-2013, 13:09
FRC #0079
Dangit man, I just finished converting to coffeescript and started putting a front end on it! Mind posting your diffs?
http://bl.ocks.org/schreiaj/raw/6604...a78a8c98eda1b/ It's still missing the axis so it's kinda useless to get numbers out of but I'll post the updated version tonight once I get the axis un-inverted.
Current coffeescript port available at https://gist.github.com/schreiaj/660...a78a8c98eda1b/
Last edited by Andrew Schreiber : 19-09-2013 at 13:28. Reason: Updated Code to not break in Chrome
Unread 19-09-2013, 13:14
There's a CSdiff report in the posted ZIP file that contains the revised C code :-)
Unread 19-09-2013, 13:29
FRC #0079
Thanks, I'll get those integrated sometime in the near future.
Unread 19-09-2013, 13:46
I've got visitors coming over in 15 minutes.
Later this evening I'll strip out all the non-functional changes and give you a report of the minimum changes needed.
It's not a lot, once I get rid of the non-functional changes.
Unread 19-09-2013, 16:37
http://bl.ocks.org/schreiaj/raw/6604...a78a8c98eda1b/... I'll post the updated version tonight...
Thanks for doing this. I'm hoping your user-friendly interface will generate more interest and technical discussion, and maybe even inspire teams to conduct tests and make their data available.
Unread 19-09-2013, 17:04
FRC #0079
Here's the updated version (haven't put your code changes in yet) but I did make it a little easier to read.
http://bl.ocks.org/schreiaj/raw/6604...06fc207f7a970/
Unread 21-09-2013, 08:51
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Thanks for putting this together.
I put together this "Drag Estimator" for my HS supermileage team years ago. It is based off of the Empirical rolling resistance and wind resistance test given in the Bosch automotive handbook.
http://www.epulaski.k12.in.us/tech/s...ign/design.htm
For rolling resistance, this gives a constant coefficient and a v^2 coefficient.
Unread 21-09-2013, 13:53
I'm glad you brought this up.
I structured the code to make it very simple to change the rolling resistance model if you want to. It takes only 2 keystrokes to change the rolling resistance model from
L = Kro+Krv*V; (line #68 in the 9/19/2013_1112a code)
to
L = Kro+Krv*V*V;
In fact, you could make the rolling resistance any function of V, or even use a look-up table if you have experimental data.
However, I think the V*V term only comes into play due to air resistance at speeds much higher than FRC robot speeds. It would be enlightening to see some actual data of rolling resistance vs speed for a typical FRC robot (with drivetrain mechanically disengaged from wheels) on FRC carpet surface.
