Go to Post We have a lot of rookies, and I can't wait to see the inspiration on their faces. - Karibou [more]
Unread 19-09-2013, 17:04
Joining the 900 Meme Team
FRC #0079
Re: paper: Drivetrain Acceleration Model
Thanks for doing this. I'm hoping your user-friendly interface will generate more interest and technical discussion, and maybe even inspire teams to conduct tests and make their data available.
Here's the updated version (haven't put your code changes in yet) but I did make it a little easier to read.
http://bl.ocks.org/schreiaj/raw/6604...06fc207f7a970/
Unread 21-09-2013, 08:51
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Thanks for putting this together.
I put together this "Drag Estimator" for my HS supermileage team years ago. It is based off of the Empirical rolling resistance and wind resistance test given in the Bosch automotive handbook.
http://www.epulaski.k12.in.us/tech/s...ign/design.htm
For rolling resistance, this gives a constant coefficient and a v^2 coefficient.
Unread 21-09-2013, 13:53
I'm glad you brought this up.
I structured the code to make it very simple to change the rolling resistance model if you want to. It takes only 2 keystrokes to change the rolling resistance model from
L = Kro+Krv*V; (line #68 in the 9/19/2013_1112a code)
to
L = Kro+Krv*V*V;
In fact, you could make the rolling resistance any function of V, or even use a look-up table if you have experimental data.
However, I think the V*V term only comes into play due to air resistance at speeds much higher than FRC robot speeds. It would be enlightening to see some actual data of rolling resistance vs speed for a typical FRC robot (with drivetrain mechanically disengaged from wheels) on FRC carpet surface.
Unread 21-09-2013, 15:57
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
I structured the code to make it very simple to change the rolling resistance model if you want to. It takes only 2 keystrokes (^2) to change the rolling resistance model from
to
L = Kro+Krv*V^2;
Um... "^" is xor in C.
Unread 21-09-2013, 17:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Someone slipped into excel mode in the middle of a line of C.
Unread 21-09-2013, 21:04
Actually...
Octave, Maxima, SciLab, AWK, and RLaB :-)
Unread 21-09-2013, 23:38
FRC #0079
Actually...
Which is still less weird than the weird case of coffeescript that I found while porting this by accident...
Turns out "variable *" compiles to "variable * variable" as opposed to throwing a compile error.
Unread 02-01-2014, 15:44
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Based on the discussion on this thread (see posts #24 and #28), I've ported Ether's/Andrew Schreiber's C code to Java, and made a GUI front-end with charting. It's not the most pretty thing ever coded, but it may help to make the calculator more accessible by non-programmers. You can find the source code here, with .jar file releases here.
I'd appreciate any feedback you might have.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
