Go to Post Brains and hard work aren't necessarily about age or grade. - Redhead Jokes [more]
Unread 19-09-2013, 17:22
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Sending data through a Ethernet port
Hi
I want to send data between a computer and the cRIO.
I figure the best way is through a Ethernet cord.
at the very least, i would like to send int numbers or boolean numbers
I would like to do this in java, but i can do it in other languages if possiable
thank you in advance
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
Unread 19-09-2013, 18:25
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Sending data through a Ethernet port
Use the NetworkTables API. You can add networktables-desktop.jar as a dependency in a java project which can be read in the default networktable java API.
Here are some good examples http://www.chiefdelphi.com/forums/sh...d.php?t=103352
Unread 19-09-2013, 20:04
mrklempae mrklempae is offline
mrklempae is an unknown quantity at this point
Can't you just plug a crossover cable between the two and change your connection type on the driver station? Or is your question more complicated than that?
