Go to Post Now I'm off to see the wizard, the wonderful wizard of Cogs. - Matt Krass [more]
Unread 19-09-2013, 18:24
Dr.Bot
Posts: n/a
The mentor's tool box.
I had an unfortunate incident last Sunday. My car got broken into and my Robot Tool box got stolen. Fortunately these were stupid thieves and they left the Kinect, USB camera and Lidar unit I had sitting in the trunk. Since I had to replace everything, I thought I'd give you the list of what I take to every competition whether a mentor/ inspector etc.
I got most everything from Harbor Freight(HF) for under $100 - did need to pick up some other items from Orchard Supply(OSH).
Here's my list:
Tool box
multimeter
soldering iron
solder
flux (have to get from Radio Shack)
solder wick "
hex keys metric/sae/torx (HF sells a set of three)
screwdrivers/bits/sockets - I get a set of security bits as well
crimps and crimp connector (Harbor Freight was crummy so I got this at OSH)
wire stripper
Electrical tape (colored)
pliers (needle nose) ( I got a set of 6 assorted and picked out three including a diagonal cutter)
multi-tool (Stanley from Osh $15) It's replacing a $78 Leatherman
150 and 200mm adjustable wrenches
super glue
epoxy
Parts
fuses/breakers < raid from last year's robot
extra victor "
extra spike "
heat shrink tubing $1.50
extra wire in various sizes
nut/bolts/ pop rivets
Optional
Combo 13pc Drill Tap/die set OSH - $31 (Vermont American)
Extra safety glasses.
Depending on what I am doing - I may also have some specialty tool/parts sets for pneumatics, mechanics(chains/extrusions)
Total cost of everything was under $140. (I could of saved a little by recycling some older tools.)
Unread 19-09-2013, 20:44
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: The mentor's tool box.
Zip ties!
Helpful list, thanks.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 20-09-2013, 14:36
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Nice list.
Duct tape? Don't leave home without it.
I would add a box/open end wrench set. I only use adjustable wrenches when I don't have the right wrench.
Unread 20-09-2013, 14:52
Nate Laverdure's Avatar
FRC #2363
I find that storing low-quality duct tape in the intense heat of my car results in an adhesive that's runny and gross. I've started keeping this stuff instead.
Unread 20-09-2013, 22:12
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
I have 2 plastic toolboxes I carry and will take either one or both inside depending on what I need.
Added to what's basically been mentioned is:
tape measure (16')
Sharpies
magnet
Gear Wrenches (SAE) [Sears has these on sale for 1/2 price sometimes during different holidays]
Common taps/tap drills/center drill/counter sink
tap handle
step drill
combination square
1/2" Milwaukee Magnum Hole shooter drill (this takes up half of one of my toolboxes! This drill is an animal and handles 90% of the stuff I need a drill for. There are times when a smaller drill or battery powered is needed though)
10' extension cord for above drill
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 20-09-2013, 22:36
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Ahh, the joys of gaff tape.
There is no tape more prized and beloved by my team's students and mentors. Expensive, but (provided you're using is effectively) worth every penny.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 22-09-2013, 22:38
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
As I work for a different division of the company that makes this, I can say that it's pretty good too. Of course, nothing beats true Rigger's Tape.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
