Go to Post If it's not on fire, it's a software problem. - Matt Leese [more]
Unread 20-09-2013, 11:02
Sarakiro's Avatar
Sarakiro Sarakiro is offline
AKA: Rob
FRC #1676 (Pascack ∏-oneers)
Sarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud ofSarakiro has much to be proud of
Modifying Vexpro Ball Shifter transmissions
Hello,
Last year, Team 1676 used Ball shifters as seen here: http://www.vexrobotics.com/vexpro/ge...l-shifter.html
We had two stage transmissions, and used the standard pancake cylinders to shift from high to low. These were great on the field and relatively easy to maintain, until at Lehigh, and more frequently than not at Monty, we lost air. As most of you using the transmissions probably know, when you loose air, the transmissions shift to neutral; Thus my question: Has anyone come up with a reliable way of inserting springs into the transmission to default either a high or low gear when air is lost? beyond that, has anyone come up with a way to modify the transmission without compromising the structural integrity of the transmission case? Any suggestions?
Thanks,
Let me know
Robert Sarakin,
Mechanical Division leader 2013-2014,
Disc Acquisition Device (DAD) Leader 2012-2013,
Participant: 2011-2014
Unread 20-09-2013, 12:42
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Modifying Vexpro Ball Shifter transmissions
Originally Posted by Sarakiro View Post
Hello,
Thanks,
Let me know
Is the Cylinder designed with a spring return to center. We used them, but I haven't checked the specs on the cylinder?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 20-09-2013, 16:56
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
Specs on the cylinder. Looks like there's currently no springs.
You could switch from single rod to double rod configuration and connect springs from the chassis to the unused rod ends.
Unread 20-09-2013, 17:13
T^2 T^2 is offline
FRC #5499
How did you lose air? (I'm assuming you made a type when you said "loose".) If it was through a problem with your pneumatics system, it may be more important to secure the whole system rather than trying to rig the shifters to default to one position. (Personally, I see the default neutral as a feature, not a bug, and I wonder if 1678 might be able to take advantage of it in the future...)
Our team ran with the ballshifters last year, and though we occasionally had pneumatics leaks elsewhere in the system, the gearboxes themselves didn't present any issues in that regard. If it really concerns you, I'm sure you can rig some springs to the cylinder-pin coupler.
Unread 20-09-2013, 17:56
magnets's Avatar
magnets magnets is offline
You can probably just tie a piece of surgical tubing to some other part of the frame, then around the tip of the cylinder.
However, it's totally possible to have a pneumatic system where there are NO leaks throughout the whole season, it just takes some time. Make sure the teflon tape is applied well and in the right direction, and test ALL parts with 120 psi, and make sure that they don't drop more than 20 psi over a few hours. Use soapy water to check for leaks. Also, remember to make a tubing cuts perfectly perpendicular.
Unread 20-09-2013, 19:13
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
These are an inexpensive way of ensuring your tubing is all cut square:
http://www.mcmaster.com/#8288a51
Art Dutra IV
世上无难事,只怕有心人.
Unread 20-09-2013, 19:42
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I don't think 1676 would argue that it's not possible to avoid leaks. I don't think they're planning on allowing the leaks to continue with this robot and most likely will do everything in their power to avoid them in the future.
However, in the event a leak does occur, I think they want a fail safe so they don't also lose their ability to drive when they lose pressure.
Unread 20-09-2013, 19:59
DonRotolo's Avatar
Back to humble
FRC #0832
Precisely Sean.
Modify them to do what? That might help us help you.
Between my team and yours, we'd have to ask FRC 1677...
We lost air because of a failure. That failure mode has since been eliminated, but no doubt there are others.
I was thinking that a plain rubber band would do the trick.
Unread 21-09-2013, 00:00
T^2 T^2 is offline
FRC #5499
I would advise against it. Our team missed a potential division win in 2011 because of rubber bands. Springs are your friends.
Unread 21-09-2013, 13:30
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I would assume (I don't know the situation you were in) that rubber bands had nothing to do with missing out on a win, rather how you used them caused your problems. Rubber bands are great tools when used wisely. They are cheap, plentiful, and easy to work with. At your next competition try walking around the pits to find a direct replacement for that critical spring that you used, then try finding a rubber band... Springs are not quite as friendly going around objects, you can't tie a spring to something without using another material or drilling a hole, and if a spring breaks or deforms you have to have a replacement that is the same size and strength. We never plan to use them, but rubber bands have been necessary additions to our robots all three years and have performed near flawlessly when taken care of.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 21-09-2013, 14:07
Kernaghan's Avatar
Kernaghan Kernaghan is offline
Technical and Driver
FRC #4814 (United Robotics team of London)
Kernaghan is on a distinguished road
I wonder if there is a way of modifying the ball shifter to avoid pneumatic shifting all together, even something like using window motors(servo might not be powerful enough to shift on the fly).
______Team 4814______
"Linking London Together"
_________URL_________
Unread 21-09-2013, 18:02
DonRotolo's Avatar
Back to humble
FRC #0832
Absolutely there is, but for most, pneumatics are far more reliable, simpler, and lighter. These can easily be shifted with a servo, it that servo used, say, a Chap-Stick "extender" mechanism to do the actual pushing.
Unread 21-09-2013, 19:38
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Can't ball shifters be purchased with a servo instead of pneumatics anyways?
EDIT: 254th post goes out to the cheesy poofs. I love those guys.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 21-09-2013, 20:07
T^2 T^2 is offline
FRC #5499
No.
Unread 21-09-2013, 20:25
Billfred's Avatar
Billfred Billfred is online now
You're thinking of AndyMark's shifters (though given past rules on servos, every year we've used AM shifters we've used pneumatics).
The VexPro line is pneumatics-only.
