Go to Post you should be putting forth you best effort every time you enter the field. - Protronie [more]
Go Back   Chief Delphi > Technical > CAD
Unread 24-09-2013, 13:43
TenaciousDrones's Avatar
TenaciousDrones TenaciousDrones is offline
FRC Team 4780
FRC #4780 (The Tenacious Drones)
TenaciousDrones is an unknown quantity at this point
AutoCAD help
I'm trying to install AutoCAD on our 2gopc classmate but the window cuts of at the bottom of the screen and I have the resolution all the way up.
Unread 24-09-2013, 14:26
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: AutoCAD help
I don't know what causes that, but installing stuff on Classmates is a bad idea... Not just AutoCAD, but pretty much any stuff. I'm 100% sure the Classmate is not capable of running AutoCAD properly, without even looking at the specs and requirements.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 24-09-2013, 18:09
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: AutoCAD help
The 2goPC likely does not have enough processing power to handle complex applications like AutoCAD. Also, the lack of hard drive space makes installing any programs hard to do. See this link for AutoCAD's system requirements.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 25-09-2013, 07:50
Re: AutoCAD help
If your system does meet the requirements listed in the Autocad site, you might want to try looking at your options under the tools menu pull down. There is a tab for display in that menu and you may try changing some of the options. You didn't mention if there was a lot of room at the top. Is your Windows toolbar visible below the Autocad screen? If it is, you may simply have the Autocad tool bar closed. Try cntrl+9 to turn it on.
