Go to Post Finally!!! I love hugs. - Eugenia Gabrielov [more]
  #31   Spotlight this post!
Unread 24-09-2013, 00:23
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: How does your team crimp terminals?
From James' link, this sums up my reticence to use solder with crimped terminals.
Also from that site, here's an internal comparison of crimps using a dimpling crimper (similar to the one Richard uses), versus a ratcheting crimper. (Like Don, he cut the crimps open to show the degree to which the strands are pressed together.)
My typical practice is like Don's, except without the microscope. It's served me well so far.
  #32   Spotlight this post!
Unread 24-09-2013, 07:39
Tristan's first link is something everyone who chooses to solder should know.
We teach our students to add solder from the terminal end of the connector and then to know when too much solder is causing the wicking action mentioned in the article. Please be advised that the Amp discussion in most cases refers to the practice of using a pneumatic, bench mounted crimper. The concept is the same but that tool is much more precise and repeatable than most teams can afford. The recommendations are also for long term (years) stability and function. The wicking action as discussed causes the solder to effectively produce a solid wire connection under the wire insulation for some length away from the terminal. In some case, this could be an inch or more. This effectively takes away from the benefit of stranded wire on moving objects and transmits vibration into the component (speed controller). Please note in the dicussion that under no circumstances should you dip (tin) the wire prior to termination. This will prevent any tool from properly forming a cold weld between wire and terminal. This is the same reason wires should not be tinned prior to insertion in the PD. The terminals used there are meant for stranded wire. The wire will conform to the terminal when inserted. There are ferrules specifically designed for use in the WAGO terminal that are crimp style. These are used primarily in manufacturing to speed assembly. You may use WAGO ferrules only with the PD as other types are not designed for the current specification of the terminal.
  #33   Spotlight this post!
Unread 24-09-2013, 11:14
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
So I was crimping a insulated fork connector to a 18 gauge wire using a good set of ratcheting crimpers. I just could not get a good crimp even though the fork terminals were listed for 18 gauge wire. Maybe the wire was on the low end of the spec & the terminals were on the big end. The moral of the story is always look at the finish crimp. If you can pull the wire out or see it moving in the crimp something is wrong.
  #34   Spotlight this post!
Unread 24-09-2013, 15:47
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We tackled this problem last summer. Our solution was to purchase one of these:
http://www.harborfreight.com/hydraul...ool-66150.html
We also only use uninsulated terminals, as the hydraulic crimper destroys the plastic insulation. We then use either heat shrink or liquid tape to insulate and strain relieve the wire to terminal connection.
The first terminal I crimped with this thing blew my mind. The terminal and wire are so tightly fused, they are indistinguishable. Even the seam where the terminal overlaps is just gone. Connections made with this tool now have the pull strength of the wire itself.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #35   Spotlight this post!
Unread 24-09-2013, 19:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We use that for our SB50 terminals and 6 gauge ring terminals. It works well and produces a very strong crimp, but the dies are strangely shaped, and cause the terminals to form these "wings" out the sides. I find it too bulky, awkward, and slow for smaller terminals.
We do have a problem with inadequate grip strength in our students. I have some spring clamps students must be able to squeeze and hold all the way before being assigned to any crimping duty. If they can't do it, I offer to let the students take the clamps home to do hand grip exercises to improve their strength.
  #36   Spotlight this post!
Unread 25-09-2013, 08:35
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Just to demonstrate how easy it is to adjust ratcheting crimping tools, and that you don't have to spend a fortune on the tool or terminals to get good results, I conducted a simple experiment last night in my garage.
I took my $10 Harbor Freight crimping tool (that I think I paid $8 for), adjusted if for the horribly inexpensive wire terminal kit I also got a HF.
It took a few practice crimps and pulls to get it dialed in well, but it only took 15-30 minutes. According to this website, the mil-spec requirements for 10awg crimped wire connections is a 150lbf pull test. So, I figured out a way to do a reasonably accurate pull-test. I wrapped the wire tail through a link in my chain fall, grabbed the connector with a pair of vise-grips, stepped onto a bathroom scale (the same one we've used to weight robots several times!) and pulled until the connector failed. I just watched to see how low the scale read at the time of failure and subtracted that from my weight to arrive at the pull-strength of the crimp connection. I repeated it three times to ensure the results weren't a total fluke.
[note the appropriate attire]
Very near failure at 33.2lbs, I weighed in at 159.0lbs, so the crimp connector is sustaining about 126lbf pull right now.
All three pull tests results in failure at around 130lbf, with a spread of around 5lbf. Very consistent, and very close to the mil-spec strength of 150lbf. Not too bad for less than $20 for the tool and terminals.
For those worried about ensuring that terminals were sized and crimped properly: the ratcheting crimping tool imprints a number (or symbol) into the connectors insulation jacket. Mine imprints a dash or a dot, another pair my friend uses imprints a number. This makes is very easy to determine that the right crimping die was used in the proper orientation with a simple visual inspection. One just needs to see the number or symbol on the terminal end of the connector appropriate for the color (size) of the connector.
Sold yet?
  #37   Spotlight this post!
Unread 25-09-2013, 09:07
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
We used to have ratcheting crimpers but somehow we lost them. Which is sad because they were always my favorite and worked like 100% of the time.
Anyways, when we crimp terminals, this is the method we use
1. Normally strip the insulators
2. Get heat shrink
3. Strip wire, put it in the terminal
4. Crimp it as much as you can
5. Put as much solder as you can possibly fit, you can never have too much
6. Heat shrink it (makes it look nice and insulates)
7. Pull-test it
That works for us, and we notice when we don't solder, even with a pull test, they just randomly fall out for no reason.
Hope that helps
  #38   Spotlight this post!
Unread 25-09-2013, 10:28
hobbes20xxx hobbes20xxx is offline
AKA: Josh
FRC #2075 (Engima)
hobbes20xxx is an unknown quantity at this point
My main problem with ratcheting crimpers is that at robotics we tend to have 5 different brands of crimps, all different O.D.. In this case, adjusting your ratcheting crimper to properly crimps will not work on the other brand.
Basically - do a tug test, if it pops off, redo it.
  #39   Spotlight this post!
Unread 25-09-2013, 10:58
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
2. Get heat shrink
7. Pull-test it
Hope that helps
You can definitely have too much solder. It will wick into the wire and cause stress problems in the wire.
If you're wires are falling out using just crimp connections, it is not "for no reason," it is most likely because the crimp was not done properly.
Why do you not standardize the brand/style of crimp connector? Having five different brands kicking around is just asking for problems.
A by-hand tug test (what I assume you're talking about as I assume you don't have a real tug-test machine) does not generally result in any meaningful amount of force, as mentioned earlier. I tried a number of 'by hand' pull tests last night (putting the fitting in a vise and pulling on the wire). Results were bad, either I couldn't get a lot of force on the wire for various mechanical advantage reasons, or the wire cut into my hand quite painfully. The only meaningful test I devised with basic shop tools is described above.
Edit: that's a round-about way of saying that if a hand tug-test is causing the crimp to fail there is something very wrong in the crimping procedure that you're using. The only crimps that failed a hand tug test during my experimenting last night were ones that I accidentally made with the crimping tool facing backwards, a very serious procedure issue indeed!
  #40   Spotlight this post!
Unread 25-09-2013, 13:07
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
We use a ratcheting crimper as well.
One of our sponsors, Burndy, provides us terminals and crimp tools (since this is their business). I'm told (yet to test it) that the wire will fail before a proper crimp does. We've never had a problem with any crimped terminals, including the crimped lugs for the batteries.
Team 501 Academic Advisor, Systems Build Mentor
  #41   Spotlight this post!
Unread 25-09-2013, 13:43
AKA: Josh
FRC #2075 (Engima)
1. Because crimps are expensive, and people hesitate to throw out perfectly good material for the sake of uniformity.
2. I try to do as much purchasing as i can myself, but occasionally another person buys crimps and someone neglects to remember that brand makes a difference (e.g. Ideal crimps vs HF ones).
  #42   Spotlight this post!
Unread 25-09-2013, 15:55
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I fail to see how wire terminals are expensive... Insulated terminals from McMaster are $8.34 (50 pack, 22-18awg), $7.84 (50 pack, 16-14awg), and $9.56 (50 pack, 12-10awg). For the $75ish it costs to get a single motor controller you could have 150 of each size. I always try to order a plethora at the beginning of the season so that no reordering is ever needed.
Now, I'm not suggesting you toss the 'off brand' connectors in the trash, just put them away during the build season and only use them for off-season projects.
I'm not trying to be a pest here my team was having similar issues as yours, and the solution (order lots of the same brand connector and a ratcheting crimper) has worked very well thus far. The way I look at it: ruining one match's results due to a wire failure costs something like 1 Match / 10 Seeding Matches * $5,000 Registration fee = $500, which puts the price of nicer 'consumable' materials into perspective.
  #43   Spotlight this post!
Unread 29-09-2013, 00:41
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Originally Posted by Tristan Lall View Post
From James' link,
Tristan,
Thanks for the link. It made a believer out of me. My new ratcheting crimper is on its way.
  #44   Spotlight this post!
Unread 29-09-2013, 11:54
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Do you mean compared to soldering? Are you claiming this is true even for a crimp properly made with an appropriate tool and crimp size?
If you have the right tool, then sure, you can get a decent crimp. However, even a good crimp will introduce an amount of resistance into a wire. Soldering helps, but it can get time consuming and overdoing it is easy, especially for less experienced members. We use a ratcheting crimper for PWM cables, and a crimper sort of like what joeweber described earlier.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #45   Spotlight this post!
Unread 29-09-2013, 12:00
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
As Al said at the top of the last page, there is nothing better than a ratcheting crimper. We use one of those on all of our connections to motor controllers and motors. We do not solder those crimps to reinforce them, and we test them by having our electrical mentor tug on them.
As for the crimps going places such as the battery to the PD board or to the main breaker, our ratcheting crimper isn't big enough. We have a pair of very large crimpers (they resemble bolt cutters) that we use for battery crimps. We reinforce those with solder (which is then covered with shrink wrap).
I'll go a little off topic to talk abour PWM crimps. We've had a problem with our PWM crimps (inside the connectors) ripping out in the past. One of our newer electrical mentors showed our electrical team how to disassemble the existing PWM connectors, pull the crimps out, and how to solder them to reinforce them. After talking it over with the head electrical mentor, we decided to do something other than using the store-bought PWM cables. He bought 1000 feet of Red-Yellow-Black stranded 24 gauge (don't quote me on that; I'm pretty sure it's 24 though) wire. We cut multiple 2 foot and 3 foot lengths, and soldered the white Sidecar connectors onto one end in preparation for wiring. Then when we started wiring our electrical board, we cut the 2 and 3 foot pieces to custom lengths and added the black ends for Spikes, Talons, etc. (we used some of the 3 foot ones for things far away from the sidecar; most of the 2 foot ones were used on the electrical board). We hot glued the black ends into the motor controllers to ensure they didn't come out.
Here is a picture: http://www.chiefdelphi.com/media/photos/38635
J Wallace IV
Truck Town Thunder
Just a college student now.
