Thread Tools |
Rating:
Display Modes |
Re: FRC Blogged-Kit of Parts Drive System Option
Interesting, I wonder if this is any indication on next years game.
Looks interesting though... |
Excited to see what the new kit frame looks like. Making superstructure attachment easier might make more teams want to stick to the kitbot.
Nice work AM! |
I'm guessing the standard 12.75:1 toughbox mini with 6" wheels. That's 10.9fps unloaded and 8.83fps with standard JVN loads.
I really do wish they would give a bit more information. I always like having a KOP drive to build so my team can be trained to help rookies. If I know it was simple enough to not need it I would rather have the voucher. Giving a direct drive system to teams is very interesting. |
Anyway, I'm interested to see a sheet metal chassis that is long or wide out of the box. |
In the spreadsheet, the 8.83 number is calculated directly from the 10.9 number by multiplying by a "Speed Loss Constant" (default is 81%). This constant is not computed within the spreadsheet from user-entered info about physical loads and motive forces in the drivetrain: you get the same 8.83 answer from the spreadsheet if you change the number of motors, stall torque of motors, the mass of the robot, or gearbox/drivetrain friction. The best way to determine what value you should use for the "Speed Loss Constant" for your drivetrain is to build the drivetrain and measure its top speed, then divide that by the theoretical unloaded speed. |
Perhaps they wanted to make it easier to attach superstructures because this year's superstructures will need a lot of structural support to do some heavy lifting? I'm calling stacking game.
#7
Team 1678 did some testing earlier this year on a bot with a 2-speed gearbox. The "Speed Loss Constant" was 92% in low gear and 72% in high gear. |
#8
My conclusion now is the same as it was then: test your drivetrain instead of blowing smoke from your behind about the theoretical speed you think you'll get. |
#9
But I still think it may be possible to develop a physics-based model that will reasonably predict overall drivetrain performance -- including not only top speed but also time to reach a desired speed, time to reach a desired distance, and accel, speed, distance, motor amps, motor volts, and Coulomb consumption versus time -- based on a priori estimates of a limited number of parameters . |
