Go to Post Good drivers know the limits of their machines, but great drivers have machines with no limits. - sanddrag [more]
Unread 25-09-2013, 16:30
Arrowhead Arrowhead is offline
AKA: Daniel Brown
FRC #1369 (1369 Minotaur)
Arrowhead is an unknown quantity at this point
Code Not Downloading
So lately our team has been having problems downloading code to our robot. Sometimes we will upload the code, but the robot code light will not light up. We eventually figured out that this was happening whenever we made any PID controllers in our code (used to control motor speed). Here is the robot code with PID controllers, which doesn't work.
Minotaur FRC 1369
2013 Robot Code
Lead Cracker: Graham Peterson
Lead Lead: Daniel Brown
*Insert Important Stuff Here*
//after season 2013
#include "WPILib.h"
#include <math.h>
float p=0;
float i=0;
float d=0;
float period=0;
class RobotDemo : public SimpleRobot
Victor fl;				//front left motor:V1
Victor bl;					//back left motor:V2
Victor fr;					//front right motor:V3
Victor br;				//back right motor:V4
RobotDrive rDrive;				//declare robot drive
Victor shooterVictor;				//   front victor for shooter
Victor shooterVictor2;				//back
Solenoid loaderArm;				//declare servo for loader arm
Joystick driverStick;			//declares all 3 joysticks
Joystick driverStick2;
Joystick shooterStick;
Solenoid SC1;				//declares solenoids for climbing arm
Solenoid SC2;
Relay ts;
Encoder efl;
PIDController pfl;
Encoder efr;
PIDController pfr;
Encoder ebl;
PIDController pbl;
Encoder ebr;
PIDController pbr;
DriverStation* driverStation;
public:
	RobotDemo(void):
	fl(1),			//assign drive motors PWM ports
	bl(2),
	fr(3),
	br(4),
	rDrive(fl, bl, fr, br),			//assigns robot drive victors theiw PWM ports
	shooterVictor(6),		//assigns victor its PWM port
	shooterVictor2(7),
	loaderArm(3),			//assign servo its PWM port
	driverStick(1),			//assign joysticks their USB ports
	driverStick2(2),
	shooterStick(3),
	SC1(1),				//assigns climbing pneumatics digital output ports
	SC2(2),
	ts(8,Relay::kForwardOnly),
	efl(2,3,false,4),
	pfl(p,i,d,&efl,&fl,period),
	efr(4,5,false,4),
	pfr(p,i,d,&efr,&fr,period),
	ebl(6,7,false,4),
	pbl(p,i,d,&ebl,&bl,period),
	ebr(8,9,false,4),
	pbr(p,i,d,&ebr,&br,period)
	rDrive.SetInvertedMotor(RobotDrive::kRearRightMotor, true);
	rDrive.SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
	driverStation = DriverStation::GetInstance();
	Compressor *c = new Compressor(1, 2);
	c->Start();
	Watchdog().SetEnabled(false);
	rDrive.SetExpiration(0.1);
	rDrive.SetSafetyEnabled(true);			//sets motor saftey on for all motors
	shooterVictor.SetExpiration(0.1);
	shooterVictor.SetSafetyEnabled(true);
	shooterVictor2.SetExpiration(0.1);
	shooterVictor2.SetSafetyEnabled(true);
	void Autonomous(void)
	DriverStationLCD *ds = DriverStationLCD::GetInstance();
	ds->Clear();
	rDrive.SetSafetyEnabled(false);				//turn of motor saftey timers during autonomous for convience
	shooterVictor.SetSafetyEnabled(false);
	shooterVictor2.SetSafetyEnabled(false);
	ds->PrintfLine(DriverStationLCD::kUser_Line1, "Robot Is in Autonomous");
	ds->UpdateLCD();
	shooterVictor.Set(-1.0);
	shooterVictor2.Set(-1.0);
	Wait(5.0);
	loaderArm.Set(true);
	Wait(0.5);
	loaderArm.Set(false);
	Wait(1.5);
	Wait(0.5);
	Wait(1.5);
	Wait(0.5);
	Wait(1.5);
	shooterVictor.Set(0);
	shooterVictor2.Set(0);
		Wait(1.0);
		rDrive.MecanumDrive_Cartesian(0.2, 0.0, 0.0);
		Wait(0.5);
		rDrive.MecanumDrive_Cartesian(0.0, 0.0, 0.0);
		Wait(3.5);
		Wait(0.5);
		Wait(1.5);
		Wait(0.5);
		Wait(1.5);
		Wait(0.5);
		Wait(1.5);
		while(IsAutonomous()){
		Wait(.005);
	void OperatorControl(void){
	rDrive.SetSafetyEnabled(true);				//turn motor safety timers back on
	ds->UpdateLCD();
		while (IsOperatorControl()){
		ds->PrintfLine(DriverStationLCD::kUser_Line1, "Robot Is In TeleOp");
		driving();   			//runs drive control function
		ShooterControl();		//runs shooter control function
		LoaderControl();		//runs servo control function
		Climbing();			//runs pryamid climbing function
		t();
		float dfl=efl.Get();
		float dfr=efr.Get();
		float dbl=ebl.Get();
		float dbr=ebr.Get();
		ds->PrintfLine(DriverStationLCD::kUser_Line2, "%f",dfl);
		ds->PrintfLine(DriverStationLCD::kUser_Line3, "%f",dfr);
		ds->PrintfLine(DriverStationLCD::kUser_Line4, "%f",dbl);
		ds->PrintfLine(DriverStationLCD::kUser_Line5, "%f",dbr);
		ds->UpdateLCD();
		Wait(0.05);			//waits 0.02 seconds
	void t(){
		if(shooterStick.GetRawButton(2)){
			ts.Set(Relay::kForward);
		else{
			ts.Set(Relay::kOff);
	void driving(){
		double y = driverStick.GetY();           //variable for forward/backward movement
		double x = driverStick.GetX();           //variable for side to side movement
		double turn = driverStick2.GetX() ;        //variable for turning movement
		deadzone(y);
		deadzone(x);
		deadzone(turn);
		mecanum(y, -x, turn);
	double deadzone(double in){
		double f_in=fabs(in);
		if(in!=0){
		f_in=1.25*f_in;
		f_in=f_in-.25;
		if(in<0){
			f_in=f_in*-1;
		return f_in;
void mecanum(float y,float x,float turn){
	y=-y;
	float mfl,mfr,mbl,mbr;
	mfl=y+x+turn;
	mfr=y-x-turn;
	mbl=y-x+turn;
	mbr=x+y-turn;
	float max=fabs(mfl);
	if(fabs(mfr)>max){
		max=fabs(mfr);
	if(fabs(mbl)>max){
		max=fabs(mbl);
	if(fabs(mbr)>max){
		max=fabs(mbr);
	mfl=mfl/max;
	mfr=mfr/max;
	mbl=mbl/max;
	mbr=mbr/max;
	pfl.SetSetpoint(mfl);
	pfr.SetSetpoint(mfr);
	pbl.SetSetpoint(mbl);
	pbr.SetSetpoint(mbr);
	void ShooterControl(){			//shooter control function
		if(shooterStick.GetRawButton(1)){
		shooterVictor.Set(-1.0);			//if trigger is pressed, turn on shooter
		else{
			shooterVictor.Set(0);			//if trigger is pressed, turn on shooter
	void LoaderControl(){			//servo control function
		if(shooterStick.GetRawButton(3) && shooterStick.GetRawButton(1)){
			loaderArm.Set(true);	//if middle button is pressed, extend servo
		else{
	void Climbing(){						//pyramid climbing function, happens automatically
		if( shooterStick.GetRawButton(4)){		//if button 6 pressed on both sticks, starts climb
		ds->PrintfLine(DriverStationLCD::kUser_Line6, "Arms Up");
		SC1.Set(true);
		SC2.Set(true);
		if(shooterStick.GetRawButton(5)){
			ds->PrintfLine(DriverStationLCD::kUser_Line6, "Arms Down");
			SC1.Set(false);
			SC2.Set(false);
	void Test() {
		Compressor *c = new Compressor(3, 2);
			c->Start();
			Wait(0.05);
START_ROBOT_CLASS(RobotDemo);		//starts the class running
and here is the code that does work, the only difference being that the PID controllers are taken out.
Minotaur FRC 1369
2013 Robot Code
//after season 2013
#include "WPILib.h"
#include <math.h>
float p=0;
float i=0;
float d=0;
float period=0;
Solenoid SC2;
Relay ts;
Encoder efl;
public:
	RobotDemo(void):
	bl(2),
	fr(3),
	br(4),
	shooterVictor2(7),
	driverStick2(2),
	shooterStick(3),
	SC2(2),
	efl(2,3,false,4)
	c->Start();
	ds->Clear();
	ds->UpdateLCD();
	Wait(5.0);
	Wait(0.5);
	Wait(1.5);
	Wait(0.5);
	Wait(1.5);
	Wait(0.5);
	Wait(1.5);
		Wait(1.0);
		Wait(0.5);
		Wait(3.5);
		Wait(0.5);
		Wait(1.5);
		Wait(0.5);
		Wait(1.5);
		Wait(0.5);
		Wait(1.5);
		Wait(.005);
	ds->UpdateLCD();
		t();
	void t(){
		else{
	void driving(){
		deadzone(y);
		deadzone(x);
		deadzone(turn);
		if(in!=0){
		f_in=1.25*f_in;
		f_in=f_in-.25;
		if(in<0){
			f_in=f_in*-1;
		return f_in;
	y=-y;
	mfl=y+x+turn;
	mfr=y-x-turn;
	mbl=y-x+turn;
	mbr=x+y-turn;
	if(fabs(mfr)>max){
		max=fabs(mfr);
	if(fabs(mbl)>max){
		max=fabs(mbl);
	if(fabs(mbr)>max){
		max=fabs(mbr);
	mfl=mfl/max;
	mfr=mfr/max;
	mbl=mbl/max;
	mbr=mbr/max;
		else{
		else{
		SC1.Set(true);
		SC2.Set(true);
			SC1.Set(false);
			SC2.Set(false);
	void Test() {
			c->Start();
			Wait(0.05);
Unread 25-09-2013, 17:08
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Re: Code Not Downloading
I'm not sure if this is what's causing your issue, but you need to enable your encoders and PID controllers, like this:
efl.Start();
efr.Start();
ebl.Start();
ebr.Start();
pfl.Enable();
pfr.Enable();
pbl.Enable();
pbr.Enable();
Unread 26-09-2013, 00:18
I suspect it doesn't like getting a period of 0. What is printed to the console?
Unread 26-09-2013, 11:59
AKA: Daniel Brown
That would make sense...
Ill try it at practice today and see if that fixes the issue.
Unread 26-09-2013, 12:00
AKA: Daniel Brown
efl.Start();
efr.Start();
ebl.Start();
ebr.Start();
pfl.Enable();
pfr.Enable();
pbl.Enable();
pbr.Enable();
Thanks, adding it now.
