Go to Post The difference between a Tinkerer and an Engineer is that the Engineer will be able to tell you the results before you start. - DonRotolo [more]
Unread 26-09-2013, 20:25
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
InternalButton based on axis inputs
I remember seeing a team's nice InternalButton implementation that would take a GenericHID (or Joystick?), an exis specification, and a threshold, and produce a couple of InternalButton objects ; the idea being that commands could be trigger off the joystick (or DPAD) position.
I thought I had it safely squirreled away, but it's not coming up.
Has anyone else seen this? Don't want to write something that's already out in the wild....
Unread 26-09-2013, 23:05
Re: InternalButton based on axis inputs
Here it is in C++ http://www.chiefdelphi.com/forums/sh...29&postcount=6
Unread 27-09-2013, 10:31
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Here's a not-quite-generic version in Java, but could easily be modified to be generic to your needs:
https://github.com/frc1675/frc1675-2...PadButton.java
edit: looking at it again, this is such a short class that "modifying it to your needs" is basically rewriting the class, haha. I also looked at the javadoc for InternalButton, and we didn't use this as one, but I'm pretty sure it could just extend InternalButton instead if you wanted access to setPressed().
Unread 28-09-2013, 16:16
fovea1959's Avatar
AKA: Doug Wegscheid
Thanks!
and the third answer from team 2168,very similar to both the above.
https://gist.github.com/jcorcoran/5743806
comments are not quite right around the description of the constructor, but it's also nice to use.
