Go to Post When you and your friend consider dressing up as a Potentiometer and “magic smoke” for Halloween! - BX MARK [more]
Unread 16-02-2013, 12:37
idooriane idooriane is offline
Electrical Head Team
FRC #1943 (NeatTeam)
Team Role: Electrical
idooriane is an unknown quantity at this point
Need Help In Connecting Accelerometer
Hey,
I have an accelerometer and gyro on the same board (photo below...), but I don't know how to connect them.
I think the model of the accelerometer is ADXL345 and about the gyro I don't know the model.
Thanks
NeatTeam #1943
Unread 16-02-2013, 14:33
Re: Need Help In Connecting Accelerometer
Originally Posted by idooriane View Post
Hey,
TeamCodeOrange video:
3:56-6:06 gyro, uses PWM cable, connects to analog input
6:07-8:06 accelerometer (requires 4 PWM cables going to 4 PWM inputs on DSC, or a custom cable for plugging into I2C on DSC)
http://www.youtube.com/watch?v=5dCwb...me0nC_xUILWCam
Unread 17-02-2013, 05:29
Thanks for the help!!
Unread 17-02-2013, 10:27
The ADXL345 example projects in LabVIEW have details on exactly how to wire it and exactly how to initialize and read values from it. I've only ever used the I2C communication, but I know it works, and it only uses four wires.
Unread 29-09-2013, 13:39
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Has anyone seen a source for prefrabicated multidrop I2C cables?
What about SPI cables that can be attached to sidecar?
Unread 29-09-2013, 13:59
We used 2 PWM cables for our SPI device. One was oriented traditionally and had power, ground, and one signal for the device. The other was oriented horizontally and carried the other 3 signals.
If you want to use SPI in java, be sure to grab the class here: http://firstforge.wpi.edu/sf/go/artf1567
Unread 29-09-2013, 21:31
fovea1959's Avatar
AKA: Doug Wegscheid
will try that a little later this week.
Was wondering if anyone had cabled multiple devices to SPI or I2C, and how they fabricated cables.
