Go to Post Thanks for the wishes of luck. We try to minimize its importance, but having it on our side is never a bad thing. - Madison [more]
Unread 02-10-2013, 14:48
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Durability in FRC
During 2013 and going into 2014 we are keeping maintenance in mind.
This past year our shooter was very easy to maintain with an easy access panel for changing shooter wheels. Our shooter motors were mounted to a separate plate that we could undo four bolts to drop out the motors and swap it with a spare assembly if a motor died. Our climber was also attached using 3 bolts so a replacement was an easy swap.
Our drivebase wasn't the easiest to keep up over the course of two regionals, Champs, IRI, and 2 off-seasons so we are working on a simpler base that is reliable but makes it easy to replace parts.
1058 PVC Pirates 2016 - xxxx
