Go to Post If it walks like a duck, and talks like a duck could be a very clever animatronics display created by Disney Imagineers.... Sometimes it is just a duck. - IKE [more]
Unread 04-10-2013, 18:45
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Re: Plotting Location w/ Accellerometer Project
Originally Posted by Invictus3593 View Post
I just tried to write up a point overlay in the dashboard like you said using the IMAQ Point overlay vi, but I can't seem to get it to actually plot a few points on the image, do you have any examples? Do you have any sample code left?
Unfortunately, I do not have any code to show and I do not have access to the libraries to recreate it. I may be able to get an example together when I go home this weekend and can get to my laptop, but until then, I can share nothing. I would only recommend that you make sure you apply the overlay after the dashboard clears the pre-existing overlays. It also may not hurt to test the overlays on a stock image (i.e. read an image from a file and try and apply the overlay; it will help make sure the process is correct.) I will post some code if I get a chance.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 05-10-2013, 19:41
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
That may be what I missed, it already overlays the points on a bmp of the field found here.
Here's how we used an XY graph to show a robot's path with a cursor showing current position.
What System did you use to get the X and Y values of the robot's position?
Per Audacia Ad Astra
Unread 06-10-2013, 23:55
If it already overlays the points, is there any issue?
Additionally, your robot x and y coordinates would probably be generated using the algorithm this thread was discussing earlier and pulled from the robot to the dashboard. Correct me if I am wrong, but I thing Joe used simple input controls to illustrate the point (no pun intended) of using an XY Graph.
2015:
2014:
2013:
2012:
Unread 07-10-2013, 08:51
The equations and code for getting X, Y, and orientation from 3 omni follower wheels is discussed in Post 11 in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=120022
Unread 07-10-2013, 09:06
-That's just it, I can't get it to overlay points with the IMAQ overlay, I have yet to try Joe's method, but it looks promising!
-I did see that, and I was thinking about using the SmartDashboard to read the encoder values from the robot, just the numeric values, then do the calculations on the driver station, reducing CPU usage.
Thanks! I was wondering what the configuration of the wheel would look like. Also, the code really helped clear up confusion I had about how position would be calculated. So on the dashboard, one would just need to read the X, Y, and Q values and set them on the graph? The Arc & Chord pdf later in that thread helped a lot as well.
