Go to Post There MUST BE room for mistakes. That’s one of the best ways to learn. - Ken Leung [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 04-10-2013, 22:31
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Re: calculating position using follower wheels
I did have it rotate counter-clockwise (oops). Corrected answer is the same, with both coordinates their opposites.
--Jacob
Illinois FTC FTA
Unread 05-10-2013, 09:13
Great work, Jacob and Ryan. Reps to you both.
Ryan: what CAS did you use for that? The syntax you used was rejected by Maxima, Octave, and SciLab. (I got it to work in Maxima by changing the syntax a bit)
Jacob: You got the right answer, but didn't show your work. How did you solve it?
This has a potential practical application for FRC. If you put 3 omni follower wheels -- in the the correct configuration -- on a robot, you can get FWD, STR, and RCW information from them. Then you can use something like the attached C code to get the position and orientation of the robot.
Name:	3 omni follower wheels.png
File Type: txt 3 omni followers C code.txt (974 Bytes, 47 views)
Unread 05-10-2013, 10:01
FTC FTA
I used Microsoft mathematics, which only allows radians in calculus functions:
X:
integral((5+1t)cos((90-15)(pi/180)-120pi/180t)+3sin((90-15)(pi/180)-120pi/180t), t, 0, 3)
Y:
integral((5+1t)sin((90-15)(pi/180)-120pi/180t)+3cos((90-15)(pi/180)-120pi/180t), t, 0, 3)
--Jacob
Illinois FTC FTA
Unread 05-10-2013, 11:08
Question 4:
In the code block highlighted in blue at the bottom of post 11 the following code appears for calculating position and heading:
Q+=dR/2.0;
X+=dF*sin(Q)+dS*cos(Q);
Y+=dF*cos(Q)-dS*sin(Q);
Q+=dR/2.0;
Give the mathematical justification for updating the heading "Q" twice in half-steps, instead of doing it like this:
Q+=dR;
Unread 05-10-2013, 12:06
FTC FTA
Spoiler for Justification:
For a given time interval, the robot turns from Q_i to Q_f. The average velocity over that time period is not in the direction of Q_i or Q_f, but somewhere in between; within the sample rate of the idler wheels, the most accurate angle is halfway in between. Therefore, half of dQ is added before, then the sin and cos of Q are used to calculate the new X and Y positions, and then the other half is added.
It is not the best proof, but it explains the general reasoning.
--Jacob
Illinois FTC FTA
Unread 05-10-2013, 12:23
Excellent. A very intuitive explanation.
See attachment for additional explanation using geometry and a bit of calculus.
Unread 06-10-2013, 21:37
Just for fun.
ID:	15276  Click image for larger version
ID:	15277  Click image for larger version
ID:	15278  Click image for larger version
ID:	15279  Click image for larger version
Name:	path distance vs time.png
Unread 06-10-2013, 02:20
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
It's Mathematica's syntax, which is also accepted by Wolfram Alpha, making it useful for quick one-line integral problems.
FRC 766, 2015-, Mentor
