Go to Post Really let's not remove the best part of the games and that is the human interaction with the robots. Humans are much more adaptable and interesting when it come to problem solving. - Steve W [more]
  #31   Spotlight this post!
Unread 04-10-2013, 18:45
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
Re: Plotting Location w/ Accellerometer Project
Originally Posted by Invictus3593 View Post
I just tried to write up a point overlay in the dashboard like you said using the IMAQ Point overlay vi, but I can't seem to get it to actually plot a few points on the image, do you have any examples? Do you have any sample code left?
Unfortunately, I do not have any code to show and I do not have access to the libraries to recreate it. I may be able to get an example together when I go home this weekend and can get to my laptop, but until then, I can share nothing. I would only recommend that you make sure you apply the overlay after the dashboard clears the pre-existing overlays. It also may not hurt to test the overlays on a stock image (i.e. read an image from a file and try and apply the overlay; it will help make sure the process is correct.) I will post some code if I get a chance.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
  #32   Spotlight this post!
Unread 04-10-2013, 23:44
Originally Posted by Greg McKaskle View Post
You could also do this in an XY graph.
Here's how we used an XY graph to show a robot's path with a cursor showing current position.
  #33   Spotlight this post!
Unread 05-10-2013, 00:06
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by Joe Ross View Post
Here's how we uses an XY graph to show a robot's path with a cursor showing current position.
Joe, what functional purpose does the X-Y graph have?
  #34   Spotlight this post!
Unread 05-10-2013, 11:20
Just for display and debugging.
  #35   Spotlight this post!
Unread 05-10-2013, 19:41
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
That may be what I missed, it already overlays the points on a bmp of the field found here.
What System did you use to get the X and Y values of the robot's position?
Per Audacia Ad Astra
  #36   Spotlight this post!
Unread 06-10-2013, 23:55
If it already overlays the points, is there any issue?
Additionally, your robot x and y coordinates would probably be generated using the algorithm this thread was discussing earlier and pulled from the robot to the dashboard. Correct me if I am wrong, but I thing Joe used simple input controls to illustrate the point (no pun intended) of using an XY Graph.
2015:
2014:
2013:
2012:
  #37   Spotlight this post!
Unread 07-10-2013, 08:51
The equations and code for getting X, Y, and orientation from 3 omni follower wheels is discussed in Post 11 in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=120022
  #38   Spotlight this post!
Unread 07-10-2013, 09:06
-That's just it, I can't get it to overlay points with the IMAQ overlay, I have yet to try Joe's method, but it looks promising!
-I did see that, and I was thinking about using the SmartDashboard to read the encoder values from the robot, just the numeric values, then do the calculations on the driver station, reducing CPU usage.
Thanks! I was wondering what the configuration of the wheel would look like. Also, the code really helped clear up confusion I had about how position would be calculated. So on the dashboard, one would just need to read the X, Y, and Q values and set them on the graph? The Arc & Chord pdf later in that thread helped a lot as well.
