Go to Post A winning robot is not a winning robot unless you have winning drivers too. You need the time to develop both. - Jim Zondag [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 05-10-2013, 11:08
Re: calculating position using follower wheels
Question 4:
In the code block highlighted in blue at the bottom of post 11 the following code appears for calculating position and heading:
Q+=dR/2.0;
X+=dF*sin(Q)+dS*cos(Q);
Y+=dF*cos(Q)-dS*sin(Q);
Q+=dR/2.0;
Give the mathematical justification for updating the heading "Q" twice in half-steps, instead of doing it like this:
Q+=dR;
Unread 05-10-2013, 12:06
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
Spoiler for Justification:
For a given time interval, the robot turns from Q_i to Q_f. The average velocity over that time period is not in the direction of Q_i or Q_f, but somewhere in between; within the sample rate of the idler wheels, the most accurate angle is halfway in between. Therefore, half of dQ is added before, then the sin and cos of Q are used to calculate the new X and Y positions, and then the other half is added.
It is not the best proof, but it explains the general reasoning.
--Jacob
Illinois FTC FTA
Unread 05-10-2013, 12:23
Excellent. A very intuitive explanation.
See attachment for additional explanation using geometry and a bit of calculus.
Unread 06-10-2013, 21:37
Just for fun.
ID:	15276  Click image for larger version
ID:	15277  Click image for larger version
ID:	15278  Click image for larger version
ID:	15279  Click image for larger version
Name:	path distance vs time.png
Unread 06-10-2013, 02:20
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Ryan: what CAS did you use for that? The syntax you used was rejected by Maxima, Octave, and SciLab.
It's Mathematica's syntax, which is also accepted by Wolfram Alpha, making it useful for quick one-line integral problems.
FRC 766, 2015-, Mentor
