Go to Post Imagine the pressure on Dave Lavery - every time he sneezes someone assumes it's a game hint. - Gary Dillard [more]
Unread 05-10-2013, 20:43
yash101 yash101 is offline
AKA: null
Re: Robot heart attack
Maybe a dead digital sidecar, or even worse, a dead cRIO. Some thing similar happened to our robot last year. During the last elimination match, our robot executed the autonomous "properly" and we, lost full control of the robot. When we checked our robot, we found that our cRIO was toast, but a computer instead of a piece of bread. Thankfully, we were carrying an extra cRIO with us. That saved us and got us into, I believe, the quarterfinals.
Unread 06-10-2013, 16:11
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Have you reverted to the original configuration (plug everything back in) with a fully-charged battery yet? Set a baseline and work from there. Maybe your diagnostic messages also existed prior to unplugging the systems.
Unread 07-10-2013, 15:56
TK3950 TK3950 is offline
AKA: Tim the Enchanter
FRC #3950 (Robo Gym)
Team Role: Electrical
TK3950 is an unknown quantity at this point
We immediately put everything back into place and used a fully-charged battery, but it has made no difference. I suspect the diagnostic errors were probably there, but I can't be sure, as I never checked before.
Originally Posted by Secretspy97 View Post
Last year, week 5 of build season we had a similar problem happened to us. When the robot was enabled the cRIO wouldn't respond to inputs or print out data. We removed the cRIO and tried another one but had the same problem. Next we checked the digital sidecar. We went one by one removing the PWM cables to see if there was any small piece of metal shorting out the board. We eventually found the shaving and once it was removed the robot once again functioned properly.
The cRIO might be the problem, but I can't be sure. I thought that there might possibly be a shaving or other metal debris interfering, as I noticed quite an accumulation of dirt and dust. I'll check the PWM cables tomorrow, but I wouldn't be surprised if there's a short somewhere. I'm no expert, but it just seems odd to me that every motor controller would give the same signal if there was only one short.
Electrical and Programming (mainly electrical)
Robogym, Team 3950
DON'T PANIC
Unread 08-10-2013, 19:36
So our problem has been resolved!
We did a lot of troubleshooting today, and after going through many of the electronic systems one at a time, we finally go to the point of switching out to our old Digital Sidecar. Once we switched to the old Sidecar, everything suddenly worked (sort of). A few tweaks to the wiring and some cleanup work, and the robot was working almost perfectly (just a pneumatics leak we intend to fix).
The Problem
The Digital Sidecar was broken. It didn't seem like it was, though. It gave us the lights we expected, but wouldn't delivier signals. Turns out the Voltage Regulator at Q1 was fried. I'll explain more in a little while.
Robogym, Team 3950
DON'T PANIC
Unread 09-10-2013, 08:25
protoserge's Avatar
The Problem
Broken is the normal mode of operation I think they had quality escapes that somehow worked
It's great to hear you got it working. My team has been through at least 4 in the past two years; I feel your pain.
