Go to Post that....was more far-fetched than the tennis ball I threw for my dog earlier today... - TeknicllyInsane [more]
Go Back   Chief Delphi > Other > Math and Science
  #31   Spotlight this post!
Unread 07-10-2013, 22:12
Re: calculating position using follower wheels
Originally Posted by flameout View Post
this is way too easy when all I need to do is change a script I already wrote.
Yeah; I had already prepared Question 6 back when everyone was using a closed-form analytical solution for Q(t). You beat me to the punch by setting up your numerical integration script.
Question 6 solution:
Spoiler for solution:
Position: ( -3.7271, -4.0749)
Distance: 60.8613
I think you are showing more decimal places than are warranted for the accuracy of your solution method. I'm differing from you in the third decimal place for X and Y. Compiled C on 8-year-old 32-bit Windows XP machine takes roughly 40ms to compute.
Can someone else weigh in with their numbers for this?
  #32   Spotlight this post!
Unread 07-10-2013, 22:28
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Makes sense.
Distance: 60.8613
I never bothered to do any accuracy analysis, so that's probably the case.
After lowering the tolerances and calculating bounds for the error (total error should be less than 1e-7), I got the following revised figures:
Position: (-3.7350, -4.0685)
Distance: 60.8668
New parameters and error analysis:
Relative and absolute tolerances set to 10^-12 (previously 10^-6): The error at each step should not exceed max(10^-12, |x * 10^-12|), where x is the current value of the ODE solution
Number of ODE solver steps: 1022
Maximum element of the state: 60.8668
Upper bound for error: max(10^-12, |60.8668 * 10^-12|) * 1022 = 6.2267e-08
  #33   Spotlight this post!
Unread 07-10-2013, 23:10
After lowering the tolerances and calculating bounds for the error (total error should be less than 1e-7), I got the following revised figures...
Distance: 60.8668
That matches my results out to the number of decimal places shown, except I'm getting a 6 instead of a 5 in the fourth decimal place of the Y value.
  #34   Spotlight this post!
Unread 08-10-2013, 00:10
AKA Ryan Van Why
FRC #0957 (SWARM)
I re-ran my script once for each of MATLAB's ODE solvers, adjusting the tolerances as necessary to get a reasonable solve time.
Every solver agreed through the fifth decimal place (for the Y value). The stiff solvers needed significantly larger error tolerances and took more steps; their predicted error was much higher.
The nonstiff solvers all agreed through the seventh decimal place.
The lowest predicted error was obtained through the ode113 solver, using a relative tolerance of 100 * epsilon and an absolute tolerance of 10^-12. According to my error estimate, all of the following digits are correct:
Position: (-3.73497544, -4.06852591)
Distance: 60.86682701
It was interesting going through all the solvers -- many of the stiff solvers had error estimates in excess of 10^-4. I guess this shows that the choice of solver really can have an effect on the error, and not just the solution time.
  #35   Spotlight this post!
Unread 08-10-2013, 00:50
The rotate_CW function has some nasty behavior near zero. So I tried replacing the numerical integration of that function in the region T<0.01 with an analytic solution of a 3rd order Taylor expansion. I'm now matching your results with a time step of 1 microsecond.
Bleary-eyed, time to call it quits for the night.
  #36   Spotlight this post!
Unread 01-11-2013, 17:53
The large black rectangle in the attached sketch represents a top view of a robot.
The forward direction of the robot is upwards in the sketch.
The 4 red arrows represent 4 unpowered instrumented (with encoders) omni follower wheels. For each of the wheels, the arrow points in the + direction for that wheel.
Question7
Find the formula for the FWD (forward), STR (strafe right), and RCW (rotate clockwise) robot motions in terms of the X1, Y1, X2, and Y2 wheel speeds.
  #37   Spotlight this post!
Unread 01-11-2013, 18:39
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Spoiler for Question 7:
FWD=(Y1+Y2)/2
STR=(X1+X2)/2
RCW=(X1-X2)/L=(Y2-Y1)/W
FRC 766, 2015-, Mentor
Last edited by RyanCahoon : 01-11-2013 at 19:35. Reason: had the rotation sign inverted
  #38   Spotlight this post!
Unread 01-11-2013, 19:51
FWD=(Y1+Y2)/2
STR=(X1+X2)/2
Looks good to me. Anybody disagree or have questions?
