Go to Post Bomb squad, that grabber was the coolest way to grab a tetrahedral object in the history of grabbing tetrahedral objects. - IronVulture [more]
Unread 08-10-2013, 11:13
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Optimal Wheel Placement for 4-wheel drive
If you're really set on doing 4 wheel drive, you can try replacing two wheels (front or back pairs) with omni wheels. It makes turning very easy, but it also means that you'll turn if your hit from the side a bit easier. The only real way that 4 wheel drive robots with all traction wheels can work is with wide robots where the front and back wheels are close together. Even then it's not all that great (Except for Lunacy. Then it really didn't matter where you had the wheels )
2016: Lake Superior WFFA
