Go to Post This is a game folks, and rules are rules, even if you kinda sorta broke one rule in the end its still broken - Mike Schroeder [more]
Unread 08-10-2013, 12:31
thegame thegame is offline
thegame is an unknown quantity at this point
Deploying code in labview
Hi I'm from a team here in houston. I was wondering what is the full proccess to deploy and launch the code in labview and FRC dashboard.
Unread 08-10-2013, 12:52
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Re: Deploying code in labview
You have to go to the project window in LabVIEW, build all, and then deploy to real-time target
Unread 08-10-2013, 13:12
Tether your programming laptop to the cRIO.
Open your robot project in LabVIEW.
On the Project Explorer window...
All the way at the bottom of the list of folders you'll see
Build specifications
Expand it to see -> FRC Robot Boot-up Deployment
By right-clicking on FRC Robot Boot-up Deployment you'll get a pop-up menu.
- Choose "Build" and wait a few minutes for it to compile.
- Power up the robot (this is when you have to be connected to it)
- Then right-click on FRC Robot Boot-up Deployment again for the menu.
- Choose "Run as startup"
It'll take a few minutes to get your code onto the cRIO permanently.
-It'll ask if you want to reboot the robot, choose "Yes"
Start your driver station.
Make sure you have wireless or tethered connectivity to the robot.
Unread 08-10-2013, 13:13
You might find the documentation helpful.
http://wpilib.screenstepslive.com/s/3120
http://wpilib.screenstepslive.com/s/...abview-program
