#106
Re: Championship Location Announced
Given that you've shown the ratio varies wildly from region to region and year to year, what causes you to draw this conclusion? Don't you think there are other factors in play?
#107
I'm drawing this conclusion based on the updated number of seats HQ assigned to our two 2013 district championships. I expect the number of seats awarded to our four 2014 district championships will keep pace at around 1 team in 7.7-7.8. Maybe I'm wrong, but thats what I'm expecting.
Anybody know if the number of qualifiers from MI, MAR, PNW, and NE are announced for 2014 yet? Ontario will roughly keep pace with the 1 team in 4 rate in 2014, with 5 regionals qualifying 30 teams, from an estimated 115-120 competing. |
#108
As several other people have mentioned, due to the large average size of FRC teams along with the volume of teams at CMP, we're approaching the maximum capacity of any city to host the event. I don't think you can take many more than 400 teams to a single city to compete due to the physical limitations of the city itself, I can't think of very many places that can handle a regular population influx of 25,000+ people in one week. Instead of increasing the size of CMP I think the only solution (as previously mentioned) is adding another layer of qualification, e.g. super regionals. Looking at other highschool sports their qualification ladder goes something like this:
divisions --> sections --> regions --> states --> nationals --> worlds. FRC could adapt a similar method with districts --> regionals --> CMP. I hope I'm not being redundant but I'm just casting my vote. |
#110
His point is you'd have a really hard time setting up stands in a convention center at the scale required. You're basically constructing an arena. This is from Einstein in 2002 when championships was 290 FRC teams, no FTC, and far fewer FLL teams. Think about how much bigger that has to be to accommodate basically twice as many people.
#111
I don't believe that we've reached the maximum feasible size for CMP. I agree there are few places that have the space and the ability to deal with the influx of people a bigger CMP would require. I would say, actually that there is just two. Orlando, and the OCCC, or Atlanta, and the GWCC/Georgia Dome. Examining dual-field divisions a bit further: I think we all agree that GWCC had significantly more space than we needed for the pits. Enough to easily house up to ~600 FRC teams, plus FLL and FTC, still with room to spare. This: Is an NFL-football field (large rectangle, 360x160ft), with 12 FRC-field sized areas (40x70ft) drawn on it. The truth of the matter is that the floor of both the EJD and the GD are significantly larger than an NFL field, so things wouldn't be quite this cramped. While Einstein is being used for FLL, it could be curtained off from Archi and Curie to reduce noise pollution. Then for the Einstein rounds, some of the Archi and Curie seating can serve dual-duty with the curtains dropped. In 2013, we played 134 matches per division, with an average cycle time of 7:03, with 100 team divisions. Each team played 8 matches, except 4 per division who each played a surrogate match. With a match cycle time of 7:03, there is no reason to believe that achieving 200% of a single field's matches is impossible, but for sake of argument, lets say you achieve 194%. 260 matches, at 6 teams/match, and 130 teams/division = 12 matches per team. 520 team CMP capacity AND everyone gets 12 matches, without extending the length of the event. For what its worth, 7:03 cycle times is the longest cycle times CMP has had since 2008. Everyone cites a limited number of volunteers as a sticking point for a bigger CMP. I don't see that as a problem. Bigger CMP, means more teams, means more people to volunteer. |
#112
FIRST had to make Championship Qualification matches start on Thursday afternoon to get 10/team in 2010 and 11, and just 9/team in 2012. We all agree that more matches is better. Last edited by Racer26 : 08-10-2013 at 16:21. |
#114
2. There IS more room for error. 2 fields allow for less tolerance because it implies the solution to a field fault can't just be "play on another field" or "play through matches on one field while the other field sorts out it's issues" because then that could mess with match separation. |
#115
That's an unwarranted assumption. I'm pretty sure the original district-based region quota was based on how many Regional competitions it replaced, not on how many teams it involved. Besides, what is true right now might not be true later. There are rumblings of a significant revamping of how merit-based qualification might change in the near future.
#116
So you have a few extra. I know from the fields I've volunteered on they had a few extra. The goal here is to require less than 200% of the volunteers.
As long as the sequence of the matches is respected, match separation should be unaffected by playing through on the working field. |
#117
While the appeal of that format is obvious, there are significant challenges that it poises as well. The financial costs and time comittments to teams, volunteers, and FIRST/planning comittees increase with each level of competition added. For many teams, it's simply not feasible to compete four or five times in a single season. The appeal of that structure is obvious, and the logic behind it is easy to follow. But there should also be a parallel discussion. Rather than adding layers of competition, when is it time to start removing them? At what point is a "champioship event" simply not feasible? At what point is it no longer the best return on investment for the time and cost sunk into it by the participants, sponsors, and volunteers? Would FRC benefit from more of a "world festival" event similar to FLL? |
#118
That is why FiM had sent 18 teams until the 2013 season when they sent 27 teams. Mar sent 12 teams their first year based on replacing 2 regionals but for the 2013 season they sent 14. I am expecting to see something similar happen this season so I don't expect that the districts will know exactly how many teams they will send until after the payment date. |
#119
Now about the adding more fields, Einstein there leaves no VIP area to see the field. Thats been addressed here before, the VIPS will get the good seats so that doesn't work. Where is the stage and floor seating going? Yes you've managed to cram the fields in but you've left less than 10ft between fields assuming the stadium is 50ft longer than the football field. The tunnel to the convention center isn't centered on a long side so that spacing doesn't really work out. Here's a map of the dome floor from last year. Laying the fields out the way you have just isn't reasonable http://www.chiefdelphi.com/forums/at...8&d=1366812834 |
#120
I think you're forgetting that I've oversized the areas by a fair margin. An FRC field is 27x54ft, and the area I allocated for each field was 40x70. Additionally, an NFL football field is 57,600 square feet. The Georgia Dome advertises 106,000 ish square feet of floor space.
Yes, it would be tight. I think its possible. |
