Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
Unread 08-10-2013, 20:09
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Re: Championship Location Announced
Originally Posted by Racer26 View Post
Examining dual-field divisions a bit further:
Is an NFL-football field (large rectangle, 360x160ft), with 12 FRC-field sized areas (40x70ft) drawn on it. The truth of the matter is that the floor of both the EJD and the GD are significantly larger than an NFL field, so things wouldn't be quite this cramped.
While Einstein is being used for FLL, it could be curtained off from Archi and Curie to reduce noise pollution. Then for the Einstein rounds, some of the Archi and Curie seating can serve dual-duty with the curtains dropped.
In 2013, we played 134 matches per division, with an average cycle time of 7:03, with 100 team divisions.
Each team played 8 matches, except 4 per division who each played a surrogate match.
With a match cycle time of 7:03, there is no reason to believe that achieving 200% of a single field's matches is impossible, but for sake of argument, lets say you achieve 194%. 260 matches, at 6 teams/match, and 130 teams/division = 12 matches per team. 520 team CMP capacity AND everyone gets 12 matches, without extending the length of the event. For what its worth, 7:03 cycle times is the longest cycle times CMP has had since 2008.
Everyone cites a limited number of volunteers as a sticking point for a bigger CMP. I don't see that as a problem. Bigger CMP, means more teams, means more people to volunteer.
I think your missing a couple things here, First yes bigger CMP means more teams, but that doesn't necessary mean more volunteers. Many of the people that volunteer are coming regardless of if their team does or not.
Now about the adding more fields,
Einstein there leaves no VIP area to see the field. Thats been addressed here before, the VIPS will get the good seats so that doesn't work.
Where is the stage and floor seating going?
Yes you've managed to cram the fields in but you've left less than 10ft between fields assuming the stadium is 50ft longer than the football field.
The tunnel to the convention center isn't centered on a long side so that spacing doesn't really work out.
Here's a map of the dome floor from last year. Laying the fields out the way you have just isn't reasonable
http://www.chiefdelphi.com/forums/at...8&d=1366812834
