Go to Post I'm somewhat fond of saying, if your robot dosen't weigh 119.99 pounds, you forgot something. - Francis-134 [more]
Unread 08-10-2013, 23:51
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
Direct connect axis camera to computer.
This is sort of a weird question. I am attempting to use the axis camera without the robot. I connected it to the computer with the crossover cable but it seems to not seem to actually connect. Nothing shows up in the browser when I attempt to connect to it's IP. It also doesnt show up with a netstat command, which is even stranger. The camera is still configured with it's robot IP, but even with the ethernet connection properties set to the IP we use to connect to the robot, the computer still doesn't see the camera. Does anyone have any idea what I am doing wrong?
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
Unread 09-10-2013, 00:09
Hypnotoad's Avatar
Re: Direct connect axis camera to computer.
Found the problem! It seems the axis camera was reset somehow and had a random IP assigned to it. I discovered this through the axis IP utility. No clue how this happened but at least i fixed it.
My teeth are false.
Unread 09-10-2013, 08:21
If it wasn't a random IP, but instead 102.168.0.90, then what probably happened was that it was reset. Some devices do this when you hold the reset button for a extended period of time, like ten or fifteen seconds. Many devices do this when you hold the reset button while the device powers up.
Greg McKaskle
