Go to Post In fact, one of our volunteers just found out about the entire FIRST program two weeks ago and had so much fun on Thursday that he came back on Friday to help us again! - KathieK [more]
View Poll Results:
0%
Voters: 0. You may not vote on this poll
Thread Tools Rating: Thread Rating: 16 votes, 4.94 average. Display Modes
Unread 09-10-2013, 01:16
Re: 3d printers and robots
Originally Posted by team1165wins View Post
What I am thinking about to boost accuracy and resolution is to make it more "smart." If it is printing a cylinder, the printer should move the head in a circle to improve upon the resolution.
Gcode doesn't exactly do well moving in anything other than a straight line. Most machines, including 3D printers, use Gcode. What this means is that for most machines, the circles are simply very small straight line movements.
Also note: You're talking about simple X-Y movement here. You move a distance X, you move a distance Y, you can do both at once by going point-to-point... but moving in a circle is pretty tough. Not impossible, just tough. You're dealing with two quadratic variables instead of just one or none...
Also, instead of printing a thin layer at a time, print thinker layers where the shape isn't changing and print small layers where accuracy is required. Our school's ten grand 3D printer doesn't have those features!
There's a really good reason for this, that maybe you don't quite realize. One of THE key definers of resolution is the tip size--how thick the material can come out. That does NOT change. It can be changed between builds, true, but then you have to reset the calibration of the machine--there's been previous discussion on the impact of having the tip too high for the tip size or vice versa. Changing during a build means a dual-head model, with both heads having a different tip, which means changing the calibration on the fly, if I'm not mistaken. That could get ugly pretty quickly--imagine rebooting the gyro while it's processing data, because you need to change the zero point.
I bet the reason that $10K printer doesn't have those features is quite simply that the cost/benefit analysis showed that the cost of the company's time and any parts needed for extra resolution/speed would far outweigh any benefits to the consumers, and drive the price up to $15K or higher, which means fewer customers pick that company.
