Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 02-10-2013, 19:15
Re: Maintaining perfect control of mecanums using encoders?
Originally Posted by jbsmithtx View Post
So to create a balanced mecanum bot, we don't need a suspension?
If a somewhat flexible frame doesn't count as a "suspension", then you don't need a suspension.
I believe right now in our classroom we can rock the robot on the front left and rear right corners a wee bit...
That spells death for mecanum.
Unread 02-10-2013, 19:49
magnets's Avatar
magnets magnets is offline
If it's only a teeny-tiny bit, it might not end up being a problem on carpet.
If it's a lot more, you can get creative with a car jack and some straps, and bend the frame into shape again.
In order for mecanum to work properly, you need equal force pushing down on each wheel.
Unread 02-10-2013, 19:52
You need sufficient force on each wheel. The forces do not necessarily all have to be equal. Post 13.
Unread 03-10-2013, 07:51
Gdeaver Gdeaver is offline
FRC #1640
Over the years our drivers have had allot of fun having their way with Mecanum drive robots. BoB was the last fun. However back in 2012 I noticed a Mecanum drive that had some pushing power and more swerve like movement. I did notice a KOP gyro on the bot. I suspect they had a very tightly controlled closed loop system. First time I saw a Mecanum that I had some respect for.
Unread 03-10-2013, 16:58
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
I know that in 2012 lots of MAR teams saw 1370 use Mecanum wheels to push other bots about the field. However, we didn't have a working gyro or closed loop system. Most of our pushing came from the bot being 119.8 pounds!
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 09-10-2013, 11:35
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
I've been thinking about this a lot. Couldn't you, hypothetically, map the joystick value (from -1 to +1) to +/-[rate of the slowest spinning motor] and then run four continuous PID loops (using encoders) to attain that rate?
