Go to Post ...if you don't ask, you won't get. - Billfred [more]
  #136   Spotlight this post!
Unread 09-10-2013, 16:03
Re: Championship Location Announced
Originally Posted by Alex2614 View Post
Take a look at the attached PDF. Very rough, but you get the idea.
How much time have you spent on the floor of the Edward Jones Dome? I'm trying to picture it from the middle, and I'm having a hard time imagining how everything will fit. You haven't left much room for the AV support, and I don't see how any of your proposals can handle the traffic flow. Your layouts all seem to provide much less access to the entrance tunnel than exists at present.
I'm also slightly concerned about the noise from one field interfering with an adjacent one, but that wasn't really a big problem between Newton and Archimedes last year, so it's probably manageable.
  #137   Spotlight this post!
Unread 09-10-2013, 16:09
maths222 maths222 is offline
FTC FTA
AKA: Jacob Burroughs
maths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to beholdmaths222 is a splendid one to behold
One comment: concurrent adjacent FRC fields might actually be OK, given that speaker audio can be pretty directed (IE FTC), and visual distractions seem not to have been a problem for the adjacent fields in 2012-13 (I think).
--Jacob
Illinois FTC FTA
  #138   Spotlight this post!
Unread 10-10-2013, 12:38
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I have three wild ideas that may be impossible.
First of all, i don't think we need 8 divisions. I can definitely see moving to 6 divisions, though. That seems most attractive to me.
How do you work Einstein with 6 divisions? The Einstein tournament and presentation ceremony already traditionally run well after their slotted time, and adding two more divisions makes it even worse. You no longer have a clean tournament brackets like you would with 2, 4, or 8 alliances advancing, so you likely have to do some sort of round robin.
Six alliances in a round robin means five matches per alliance, or fifteen total matches. That's six to nine more matches as are currently run on Eisntein, and has no real provision for tie-breakers or a true Championship match. In other words, the final match played might not even involve the team who is crowned champion. Can you think of a more anti-climatic ending? If you attach a playoff or championship match to the back-end, it's yet more time added on to the Einstein proceedings.
Six divisions doesn't work from an Einstein perspective.
  #139   Spotlight this post!
Unread 10-10-2013, 14:06
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
This was my first concern too before even worrying about field arrangement. Einstein already takes up just about the maximum amount of time that it can without running late into the night. Having 8 divisions would mean 21 games on einstein. I can't figure out a good way of having a 6 team bracket, you can't give any teams by's into the semi's because there's no seeding order, and if you let every team play each other that's 15 games just for quarter finals. There's also always the possibility that multiple teams come out with the same W/L record screwing up the bracket.
If we do move to 6 FRC fields, those fields would have to be fields that teams from every division rotate onto to save time. However, that makes it a nightmare for teams trying to find seats and scout matches at a different field every couple of matches. 8 fields would be more manageable for teams, but it would still be problematic trying to watch and scout matches halfway across the stadium, let alone scouting multiple matches happening at once.
I don't think more than 4 FRC fields is doable unless each field is it's own division. You can't have 6 divisions because that screws up einstein, and you can't have 8 divisions because there's not enough space in the dome for 8 FRC fields, 2 FTC divisions, and an FLL hybrid einstein/presentation stage area.
Point out if I made any errors, but I just don't think expanding CMP is really possible considering these issues plus all of the previously mentioned ones.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
