Go to Post Maybe this thread should be re-titled "Waiting impatiently for the 2011 hint!" since having over 100 posts doesn't seem very patient. - Joe Ross [more]
Unread 06-10-2013, 19:36
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Giving away robot cart in SE Michigan
If you know of any team who can put this robot cart to use instead of ending up in a dumpster, please let me know.
The robot cart is based on an ATV Lift, http://www.harborfreight.com/1500-lb...ift-69995.html but it is the previous version that has a different paint color. We replaced the wheels so it moves better. We welded in some sheet steel around the base for batteries and storage space. We put wood on top and modify it each year to fit the robot.
The robot cart still works perfectly. I like it that it can go up and down to make it easier to work on the robot. However it is heavy and others on the team wanted to design and build a new one.
ID:	15274  Click image for larger version
Please don't call me Mr. Ed, I am not a talking horse.
Unread 07-10-2013, 20:38
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Re: Giving away robot cart in SE Michigan
Team 2950 will take it! But can you ship it to texas. If so could you please check your private email on the chiefdelphi. It contains our contact info so you can email us and we can work out the specifics. Thank you so much for this!
Unread 08-10-2013, 00:26
Ed Law's Avatar
I was thinking more about local pickup. It would be a lot of work to ship an item like this and it would cost over $100 just to ship. It does not make financial sense to ship this.
If you can make arrangement to pick it up, then let me know. Otherwise, it is first come first serve. It is actually sitting outside right now under a veranda. No appointment is needed to pick up. If you are interested, I will tell you where it is.
Unread 08-10-2013, 00:34
yash101 yash101 is offline
AKA: null
Our team can use something like this, but we reside across the country from you, so it would be impractical to ship it to PHX. Also, That's what HFT is for. Cheap and suckish parts to be tinkered with and made better. We have a bandsaw from HFT. Pretty cheap but nice quality. We did some adjustments and now it is just like one at least twice the price.
Unread 09-10-2013, 12:17
mcason mcason is offline
FRC #3568
mcason is an unknown quantity at this point
Our team would be interested in the cart. We are located in Linden, MI but could come and pick it up?
Let me know
Mike
Unread 09-10-2013, 14:41
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
FRC #5053
jeremy callahan will become famous soon enough
Hey Ed,
3098 would be interested in it. We can come out whenever. Just let me know.
Thanks,
Jeremy Callahan
Unread 09-10-2013, 19:52
Ed Law's Avatar
Let me know
Mike
Mike,
I replied to your PM on where to pick up the robot cart. If you change your mind because it is too far, please let me know so another team can get it.
Ed
Unread 09-10-2013, 20:18
FRC #3568
Thanks, I plan on getting it after work. You are not that far away from my work.
Thanks again
Mike
