Go to Post 10:56 p.m. EDT, July 20, 1969. - dlavery [more]
Unread 10-10-2013, 21:14
Re: [HELP] cRIO not imaging as it should be
Originally Posted by domingocool View Post
So, we've been having trouble imaging our cRIO for two days and can't seem to figure out why. We periodically get the two blinks on the status lights so we installed NI MAX 5.5 and re-formatted the cRIO and re installed the software with all the add-ons. We set out LAN IP to 10.46.45.5 and the subnet mask to 255.255.255.0. When we try to image it it still doesn't image(or at least starts but puts an error(Error 7)). Also the modules never show up on the Imaging Tool nor are the little switches usable. We've tried everything we feel that we can so any help would be awesome. Thanks.
So far as I can tell, there's never a good reason to use NI MAX on a cRIO-FRC.
You say you installed "all the add-ons"? Does that include the FRC Utilities update? Error 7 usually means that a program can't find a necessary file. Perhaps you tried to run the update from inside the compressed folder without extracting the files first.
