Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 10-10-2013, 17:23
domingocool domingocool is offline
Programmer
FRC #4645 (X-Machina)
domingocool is an unknown quantity at this point
Question [HELP] cRIO not imaging as it should be
So, we've been having trouble imaging our cRIO for two days and can't seem to figure out why. We periodically get the two blinks on the status lights so we installed NI MAX 5.5 and re-formatted the cRIO and re installed the software with all the add-ons. We set out LAN IP to 10.46.45.5 and the subnet mask to 255.255.255.0. When we try to image it it still doesn't image(or at least starts but puts an error(Error 7)). Also the modules never show up on the Imaging Tool nor are the little switches usable. We've tried everything we feel that we can so any help would be awesome. Thanks.
Unread 10-10-2013, 17:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: [HELP] cRIO not imaging as it should be
Have you pulled the modules and checked the condition of the pins in the chassis? The HD15 connectors are susceptible to bent pins if the modules are not installed correctly.
Unread 10-10-2013, 18:26
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I would start with the basics. Can you go to a command prompt and ping the crio? Let's make sure you have communication first.
Also, you are connecting your ethernet cable directly to the crio from the computer, right?
Unread 10-10-2013, 18:32
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Is it a 4 slot cRio?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 10-10-2013, 21:14
So far as I can tell, there's never a good reason to use NI MAX on a cRIO-FRC.
You say you installed "all the add-ons"? Does that include the FRC Utilities update? Error 7 usually means that a program can't find a necessary file. Perhaps you tried to run the update from inside the compressed folder without extracting the files first.
Unread 10-10-2013, 23:41
Programmer
Yes it is
Programmer
How do you go about pinging the cRIO with CMD?
Unread 10-10-2013, 23:44
Programmer
Well we used NI MAX to re-format and reinstall the software to the cRIO because the status light was showing a software blinking error. There were no compressed folders used. NI MAX was supposed to do the install without the need for extraction of any files.
Unread 11-10-2013, 00:08
Tom Line's Avatar
What IP address did you assign to the cRIO in NI MAX?
Unread 11-10-2013, 00:19
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Pinging an IP (or website)
from the desktop with all windows minimized and an Ethernet link directly from your computer to the cRIO (powered on)
-hold /windows key (meta)/ and while holding, press /r/
-type "cmd" (no quotes)
-press /enter/
-type "ping" then /spacebar/ then "your cRIO's IP" (you said before: 10.46.45.5)
-press /enter/
It should look something like picture 1 ("google.com" will be "10.46.45.5"). Of course, the ping values may be different, but that is not what you are pinging to test, you just want any reply at all. If it looks like picture 2, I would try pinging "10.46.45.1" If that fails, you may have a problem. If it works and you DO get a reply, however, there may be hope yet...
Anyways, If it is bricked, NI probably has some sort of warranty on that...
ID:	15299  Click image for larger version
Unread 11-10-2013, 00:29
Aaron.Graeve Aaron.Graeve is offline
FRC #1477 (Texas Torque)
Aaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to allAaron.Graeve is a name known to all
If they used the FRC cRIO Imaging tool, shouldn't the cRIO IP be 10.46.45.2? I think 10.46.45.5 is the IP of their driver station.
Alamo, Bayou, and Lone Star Regional FTAA
2015:
Dallas, Alamo, Bayou, and Lone Star Regional FTAA
2014:
Alamo, Dallas, and Lone Star Regional FTAA
Alamo Regional Robot Inspector
2013:
Einstein Champion and 2013 World Champion (Thanks 1241 & 610), Galileo Division Champion, Razorback Regional Winner, Alamo Regional Semifinalist, Bayou Regional Semifinalist, Lone Star Regional Quarterfinialist
2012:
Curie Division Semifinalist, Lone Star Regional Finalist, Bayou Regional Winner, Alamo Regional Winner
Unread 11-10-2013, 00:33
I am Dave! Yognaut
AKA: Brian Bray
Oh well I don't know. Just try pinging everything from ".1" to ".10" at least one is bound to work (or not)
Unread 11-10-2013, 09:32
Who told you to use NI MAX?
What instructions did you use?
What software did you reinstall on the cRIO?
How did you install the FRC Utilities on your computer, and did you apply the FRC Utilities Update?
Unread 11-10-2013, 11:18
Programmer
We set the IP to 10.46.45.2
Unread 11-10-2013, 11:19
Programmer
We set the IP of the cRIO to 10.46.45.2 and the IP of the computer to 10.46.45.5 and 6.
