Re: Show off your machining!
This was our bot the 2nd week.
http://ultimate3647.tumblr.com/post/...kend-machining Was done by myself on an CNC bridgeport and Tormach mill. |
Well I saw this beautifully machined ratcheting PTO winch gearbox at IRI with pretty tool paths and beautiful attention to detail. You can see the really nice toolpaths on the gearbox plate in the background.
And oh yeh, it's 696's. ![]() |
Supermileage, actually. And sadly we don't compete any more-- many of the students who used to compete in Supermileage moved over to FRC when the team started in 2007. Due to a lack of funds (and shop time), for better or for worse, the Supermileage team faded and eventually folded into our FRC team.
I present to you Kyle in his natural environment:
![]() I'll see if I can dig up our arm transmission from Rebound Rumble. It was manufactured using the gears out of a Harbor Freight worm gear winch, which were lightened and placed in a custom aluminum housing. |
Here's some shots of our drivetrain siderails and our new intake we built for champs. The intake was made my me on a cnc controled bridgeport and the siderails were cut at a mori seiki rnd facility on a prototype machine.
Sorry for the poor image quality. -Adrian |
#7
Also, I love that yoke. I wish I had a chance to make something that complex. It looks like you chose to pre-drill your bearing bores with a twist drill then finish with and end mill. If that's what you did, why'd you chose to do it that way instead of just milling the hole? Thanks, -Adrian |
#8
For teams with ATCs, it's generally faster to just drill a quick hole and dive your cutter into the part rather than taking a while to spiral down through the part. Of course, if you have to manually change tools, its probably faster just to spiral in. |
#9
#10
Was going to ask this as well. It looked as if they were tumbled afterwards.
#11
But Cory would know! -RC Last edited by R.C. : 15-10-2013 at 19:48. |
#12
Same. We've had some parts come off after using a 2in face mill with a similar finish.
#13
After machining they were hit real quick with a scotchbrite wheel. I like to pre-drill when convenient (as long as the drill is in the machine) as it eliminates any chance of packing up the flutes or chipping the edge of a flute when plunging. I think RC is talking about the yoke for the arm, which is shown as machined. It was scotchbrited later, but the finish you see on the outside of it is from a 3" aluminum specific face mill. |
#14
Ah, that makes sense. Thanks!
#15
This our shooter wheel this year. It weighed a little over 4lbs and had a diameter of a little over 12 inches. This started out as a 14x14 in piece of aluminum. The outer circumference was milled out, but the spokes were cut out with a wire EDM. This is very simple compared to some of the other things on this thread, but this was the first time our team had anything EDMed and it was very cool.
http://i.imgur.com/d2bTPPE.jpg Last edited by bkahl : 17-10-2013 at 16:51. Reason: bad link |
