Go to Post i build robots. i like robots. i live with robots. i love robots. i AM a robot. - tgoral2826 [more]
Unread 21-09-2013, 15:57
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: paper: Drivetrain Acceleration Model
I structured the code to make it very simple to change the rolling resistance model if you want to. It takes only 2 keystrokes (^2) to change the rolling resistance model from
L = Kro+Krv*V; (line #68 in the 9/19/2013_1112a code)
to
L = Kro+Krv*V^2;
Um... "^" is xor in C.
Unread 21-09-2013, 17:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Someone slipped into excel mode in the middle of a line of C.
Unread 21-09-2013, 21:04
Actually...
Octave, Maxima, SciLab, AWK, and RLaB :-)
Unread 21-09-2013, 23:38
Data Nerd
FRC #0079
Actually...
Which is still less weird than the weird case of coffeescript that I found while porting this by accident...
Turns out "variable *" compiles to "variable * variable" as opposed to throwing a compile error.
Unread 23-09-2013, 16:51
- added total drive motor amps to output
There's a small error in the build 9/19/2013_1112a code.
At line 75, "A*4/10" should be "A*n/10".
Unread 23-09-2013, 17:03
Data Nerd
FRC #0079
My current JS port has some minor typos that I haven't had the chance to hunt down yet. I'm working with Emscripten to compile the C code to Javascript which should mean I can integrate your changes faster too.
Unread 23-09-2013, 17:22
Originally Posted by Andrew Schreiber View Post
...should mean I can integrate your changes faster too.
That would be great.
I want to add battery voltage drop so mentors can use the model as a visual teaching tool to show students why low resistance in the motor wires and connections really does matter.
Unread 24-09-2013, 23:13
the model does not account for voltage drops due to heavy currents through the wires, the wire connection points, the battery' s internal resistance...
9/24/2013 added updated C code (build 2013-09-24_2231) which includes motor voltage drops due to circuit resistance.
9/24/2013 added an explanation how the voltage drop model was derived.
Unread 13-10-2013, 15:03
Richard100 Richard100 is offline
FRC #0836 (RoboBees)
Richard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to beholdRichard100 is a splendid one to behold
Ether - Very nice, thanks for developing this. Do you think it could be extended to include wheelbase parameters and predict motor current draw when turning (say differential steering)? We've had trouble in this area during drive system design.
Unread 13-10-2013, 15:11
Possibly. You can find several links here for static analysis of turning force (which relates to motor current) for skid-steer vehicles.
Unread 18-12-2013, 22:51
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
The executable works very well functionally-- I was able to run it with no problems and create some nice graphs based on it.
The only problem I've noticed is that I really have no idea what any of the variables are until I look back into the original program for comments.
I don't think I've quite expressed my appreciation for this program enough-- it is really nice to have such a good model for generating a good estimate of how fast a given drive train setup will move.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 02-01-2014, 15:44
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Based on the discussion on this thread (see posts #24 and #28), I've ported Ether's/Andrew Schreiber's C code to Java, and made a GUI front-end with charting. It's not the most pretty thing ever coded, but it may help to make the calculator more accessible by non-programmers. You can find the source code here, with .jar file releases here.
I'd appreciate any feedback you might have.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 17-09-2014, 09:20
Due to changes made by the web host, many of those links are now broken.
So I collected everything together in one place and posted it here.
Unread 04-10-2014, 15:21
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Thank you so much for making this. You're my go-to resource for FRC physics and the community wouldn't be the same without you.
On line 84 voltage drop is calculated, but you don't ever seem to account for it when calculating the torque of the motors, is that correct?
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 04-10-2014, 16:19
No. It is accounted for in the motor torque calculation. See the last paragraph in the voltage drop model rev E.pdf document:
In the C code, there is an accel(V) function which computes the vehicle acceleration given its speed V. The vehicle speed V is directly related to the motor speed Wm through the wheels and the transmission, assuming no wheel slip. This motor speed Wm is then used in the formula Tm=Toffset-Tslope*Wm derived above to obtain the motor torque (see line 77 in the code). By using this formula for motor torque, the voltage drops due to current are automatically included in the calculation.
If you change the values of Rone and/or Rcom, you will definitely see the effect of changed voltage drop in the model's output.
Thanks for the words of encouragement.
