Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Unread 14-10-2013, 20:28
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: "The Little Things" - Helpful hints for all
Standardize all your fasteners.
If you need more than a handful of tools to fix your robot you did it wrong.
Unread 14-10-2013, 20:56
FRC #1836 (MilkenKnights)
-This has been discussed before and there are multiple views, but I believe that crimps are better than soldering. You don't have to wait for irons to heat up(bad during elims) and is hard to mess up. We switched to all crimps this year and have had so many less problems with electrical.
Unread 14-10-2013, 20:59
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Utilize the resources that you have.
We don't have access to a CNC machine, or a waterjet, or plasma cutter, or a welder. But we do have a laser cutter capable of cutting plastic, so you will see tons of ABS plastic on our robot.
Unread 14-10-2013, 21:01
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Any code with 10 minutes of driver practice is better than PID-controlled omni-directional speed-curved code without driver practice. That being said, leftmotor = joystick1.y and rightmotor = joystick2.y should be the starting point, not the ending point for drive code.
Don't be ashamed to switch to an easier strategy. For example: this year, if you were scoring less than 50% (which many teams were) in the 3-point goal, switch to the 2-point goal.
Never leave a competition before alliance selections have finished.
Don't cause silly penalties.
Make sure that at least 2 programmers understand any given section of code.
Unread 14-10-2013, 21:30
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
-Put your bumpers as low as reasonable.
-Keep your robot's center of gravity as low as possible.
-Prioritize game piece acquisition over everything except the drivetrain itself.
, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 14-10-2013, 21:34
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
Why?
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 14-10-2013, 21:37
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Originally Posted by Samwaldo View Post
Why?
You're more likely to win pushing matches if you have lower bumpers than your opponents. Part of their weight will shift on to your robot and you will gain traction and they will lose it. It also helps to have stiff bumpers that don't move up and down at all.
Lower bumpers also normally make it harder for your robot to tip over since your at less of an angle when your bumpers hit the ground.
Unread 14-10-2013, 21:47
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Why?
While I can't speak for Bryan, I can say that the reason our team would like to do this is that lower bumpers are advantageous for CoG reasons, pushing match reasons, and avoiding tipping.
The lower CoG is quite obvious. However, less obvious are the pushing match advantages. During a pushing match, normal force is quite often transferred between the robots. Consider 2 robots with equal weight and traction capabilities, both at 145 lbs with bumpers and battery but different bumper heights. When they engage in a pushing match, it is possible that the one with higher bumpers may transfer some of its weight to the robot with lower bumpers. Now you may have the high bumper robot with 130 lbs of normal force available to "turn into" tractive force, while the low bumper robot might have 160 lbs of normal force to "turn into" tractive force. This means the robot with lower bumpers could have more pushing force due to the increased normal force on its wheels. The ground still supports the total weight of both robots, but not necessarily equally at all points. In addition the robot with higher bumpers may tend to get up-ended in this situation.
It can also help in avoiding tipping. If the bumpers are lower, they will "catch" the robot as it tips more quickly than if they are higher up. I have also seen robots tip such that their support polygon is the frame and the bumpers, which is way less probable with lower bumpers.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 14-10-2013, 21:49
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Swarf is the devil. Protect your electronics.
Tug-test all crimps.
Program manual overrides for your fancy code so that when a sensor fails or the mechanism ends up in an unexpected state, the drivers have a way to recover or work around the problem.
Remember your robot is going to have to go through doors in the bag. Plan bumper transportation accordingly.
Unread 14-10-2013, 21:50
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Focus on a strong feature of your robot and just try to make it consistent.
You're more likely to get chosen in alliance selections if you have even one feature that makes your robot stand out. Our team's success this year was largely because we had a very consistent 5-disc autonomous. A team we work closely with generally seeded higher than us last year, but didn't have one particular feature they could "sell" to other teams.
Unread 14-10-2013, 22:03
Professional Stat Padder
Plan for locations for electronics, compressors, batteries in your design, not as an afterthought.
Good scouting wins matches, great scouting wins competitions.
and related:
Good scouting is not a replacement for a good robot.
But a good robot is also not a replacement for good scouting.
Also in the thread of scouting: if you don't have the resources to scout, because you're a rookie team or have a small team, some other team does, and they are likely to accept the addition of two or three scouts into their scouting team in exchange for data.
And of course, always be graciously professional. GP in winning, GP in losing, GP on and off the field. It will get you further than any robot-related item in FRC.
(2015-Present)
Unread 14-10-2013, 22:27
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I'm sure I can think of more, but a post in the thread reminds me of a major misconception most new teams have.
Playing good defense is not about ramming or pushing your opponent. It's about preventing them from accomplishing what they want to do for as long as possible.
Avoiding defense well is not about out-pushing the defending robot. It is about evading them ask quickly as possible and continuing on to scoring.
-Plutarch
Unread 14-10-2013, 22:47
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
- Talk to people. Talk to people from other teams, talk to people on your team, know what is going on at the event, know what is going on in your own shop. Building connections with other teams can be the difference between playing on Saturday and not. Building connections within your team is the difference between existing and not. People like to work with people they know.
- Welds are light. Rivets are light. Nuts and bolts are heavy. Consider which you prefer on your robot.
- For mechanical: Programmers are your friends.
- For programmers: mechanical are your friends.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 14-10-2013, 23:48
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
Make electronics very easy to access because you never know when you need to change or replace something.
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
Unread 14-10-2013, 23:55
Andrew Lawrence
Posts: n/a
Evaluate your needs each year. Don't expect to be able to use a similar setup to a previous year just because it worked then.
