Go to Post I can see the 2013 Kickoff broadcast now: "Hello Teams. Welcome back. Gracious Professionalism. Here's some homework. Here's the animation. Here's what the actual field looks like. RTFM. Peace." - sanddrag [more]
Unread 16-10-2013, 21:22
adlasa's Avatar
adlasa adlasa is offline
President and Lead Programmer
AKA: Sasha
FRC #1458 (Red Ties)
adlasa has a spectacular aura aboutadlasa has a spectacular aura aboutadlasa has a spectacular aura about
Why is there .01 second delay in teleop on the tutorials?
I was looking at the FRC Java tutorials and noticed there was a 0.01 second delay at the end of the main teleop while loop. Why is that? I never put one in my code.
Computers run on smoke. When the smoke escapes the computers stop working.
Unread 16-10-2013, 21:46
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Why is there .01 second delay in teleop on the tutorials?
It's to reduce CPU usage by preventing the software from running more frequently than necessary.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-10-2013, 22:39
adlasa's Avatar
AKA: Sasha
That makes sense thank you. But, is there any point in reducing CPU usage, what is the advantage? It's not like you are freeing up the CPU to do other things.
Unread 16-10-2013, 22:55
The CPU also has to process incoming communication data. You will see increased latency if there isn't free CPU time.
Speed controllers are updated at a maximum of 0.005 seconds. Driver station data is received at a maximum of 0.02 seconds. 0.01 is a happy compromise. If you are only reading data from the driver station, 0.02 is all you need.
Unread 17-10-2013, 00:23
adlasa's Avatar
AKA: Sasha
Thank you for the replies guys, everything makes a lot of sense now!
Unread 17-10-2013, 13:30
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
...so is it considered good practice to add it in? If your code is entirely event based (or using threads), would you really need it?
Unread 17-10-2013, 13:44
It depends on how you implement the thread. If you create a thread which runs continuously in an infinite loop within the thread, then you need to slow down the frequency of that loop by yielding the processor for a period of time every pass through the loop.
If the thread is created, does its thing, and then exits, you don't need the yield in the thread. You just need to make sure that the parent process that is creating that thread limits the frequency at which it creates the thread.
Unread 17-10-2013, 14:14
If you are event based, then your idle loop should have a wait in it.
