Go to Post John is the king of vague, but then again he looks much better at a distance than he does up close :D - Rich Kressly [more]
Unread 16-10-2013, 02:27
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
"Out of the box designs"
Ever thought of some wacky, strange idea for tackling last (or any) year's game? Some weird robot design idea that is too stupid to build, but would be hilarious to see? Share it here. I will start:
For Ultimate Ascent I though of an defensive bot. I would call it Fan-Bot.
Here is the idea: Create a robot with a base as long and thin as allowable (48"x8" I think). Put a minimal drive-train on it (maybe 4 miniCIMs), and enough support to keep it from tipping over (deploy-able training wheels?). Powered by a every CIM you have (and maybe more) you have a huge fan with a diameter similar to the robot's length (roughly 46"). Gear it to achieve maximum rpm (pushing air requires a lot of torque), and shape it to get maximum fan-out. Direct the wind upwards via a polycarbonate wall into narrow, wide, high velocity stream that points straight up.
Park under the opponents goal, using the travel time and autonomous to "spool up" the fan.
Blow every disk shot over the 'bot upwards, sliding from left to right along the alliance wall to block a 2 point or 3 point goal. If the stream is fast enough, the updraft would easily reroute most robot's disks into the wall above the goal, due to the aerodynamic properties of a Frisbee.
Your turn!
Unread 16-10-2013, 02:36
Re: "Out of the box designs"
Though not as powerful as you might like, check out 869's robot from 2013.
http://www.thebluealliance.com/match/2013mrcmp_qm86
Unread 16-10-2013, 02:51
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
From my former team: http://www.chiefdelphi.com/forums/sh...d.php?t=111559
First comment actually guessed it pretty much exactily right.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 16-10-2013, 07:34
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
This year we had a crazy idea of doing a "Momentum Climb" We would just have a drivebase that was very fast and powerful with a hook on the top and bottom of the robot. Towards the end of the match we would drive strait at the pyramid hook and swing on then the lower hook would grab the second bar and swing us to the top hook.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 16-10-2013, 09:09
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
See this thread. That is all I will say for now.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 16-10-2013, 19:05
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
/troll
See this thread.
/endtroll
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-10-2013, 20:20
magnets's Avatar
magnets magnets is offline
The robot height rule applies only during the duration of the match, so right as the match ends, have a pneumatic cylinder pull a pin that releases a really tall arm that dumps four colored discs in the top of you pyramid goal.
Would this actually be legal? If it is, then you get 2/3 of a thirty point climb with almost no effort (compared to building a climber)
Unread 16-10-2013, 20:31
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
The robot gets disabled in between autonomous and teleop mode for a short time, releasing the pin early.
Unread 16-10-2013, 20:34
FRC #1836 (MilkenKnights)
a 2 pin system would work then. 1 gets automatically pulled 10 seconds before the match ends by code(double solenoid so there is no default). The other one would be the single solenoid one that get's pulled right after the game ends
Unread 16-10-2013, 20:39
AKA: Ervin Ibadula
FRC #0865 (Warp7)
That should work .
Unread 16-10-2013, 20:40
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
I think this is what 148 did.https://www.youtube.com/watch?v=bYgpg0k4uwI
Unread 16-10-2013, 20:45
There's a couple of reasons this wouldn't work, illegality being one.
First, the definition of scored requires the disc to be in the goal at the end of the match, which is elsewhere to be defined as when the clock hits 0 +5 seconds for stuff to stop moving.
Second, never does mean never. I'm going to argue that your "when the match ends" includes the +5 second stoppage time if I lose the match, and certainly violates the "never" in R03-C. I'll also call for a disable (G05) and an alliance DQ for a robot that was illegal (T06). And I'll request that T07 be invoked to keep you off the field until such device was taken off.
Now, if you wanted to do something similar, try modding your disc shooter so that it can also drain shots into the pyramid goals with a special speed or angle or both. I think someone actually did this. You could also try doing something that slams up to 83" and tries to push all the discs out in a nice arc on stopping, but I think that would be harder.
Unread 16-10-2013, 21:07
magnets's Avatar
You're right, it's illegal, but a "match" doesn't include the 5 seconds at the end. The game manual says matches are 2 minutes and 15 seconds long. So, you wouldn't get a foul for being too tall, but your disc doesn't count.
It looks like climbing is the only thing that gets the extra five seconds, not discs.
Unread 17-10-2013, 00:41
Nope, discs would get the extra 5 seconds if they were in motion.
You're right about not getting a foul for being too tall. The penalty for violating a robot rule is a disable (for this situation, not an issue) and/or a red card (to the alliance!) depending on whether or not you didn't pass inspection and/or shouldn't have passed inspection. No point penalty--but a DQ hurts you worse than most point penalties.
Now, here's where I think we differ: The robot rules say "never" over 84". Not the match rules, the robot rules--which apply at inspection AND during a match (and if you're breaking them elsewhere, like right after the match, the inspectors will be looking for you to show that you cannot break them on the field--oops, too late). If you break the robot rules in a match, the least you can expect is a disable; if it's something that should have been illegal by inspection, and you're on the field, red card to the alliance.
If some folks wanted to get really persnickety, you triggered the action to go over 84" during the match (and THAT you can't argue--you released the pin before the timer hit zero) and thus attempted to go over 84" during the match, and thus attempted to violate the rule during the match--you just happened to complete it during the "come to rest" time. (Not to mention any accidental deploys.) It's a thin defense that you didn't actually complete it. (I think most refs would call you on it--and the head ref's ruling is final.)
Of course, now that you've mentioned it... anyone want to take a stab at how the GDC might manage rule something like this illegal next year, using either existing or new rules?
Anyways, I don't know about y'all, but I wouldn't take the risk of no points for myself and my alliance partners if the loophole doesn't actually exist. (Now, utilizing other systems on the robot to target the pyramid goal and drop a couple of shots up there without climbing, that's another story--because I don't come close to breaking any rules.)
Unread 17-10-2013, 02:03
It's interesting because this is what I initially believed too:
"A DISC is considered SCORED in an ALLIANCE’S GOAL if any part of the DISC has crossed through the opening of the GOAL, is in the GOAL at the end of the MATCH, and is not in contact with any ROBOT from that ALLIANCE." -3.1.5.1
For a disk to be scored it HAS to be in the goal at the end of the match. This is interesting wording because it is extremely hard to judge this. In addition scoring was always confirmed based on disk in the goal even after the match ended. As far as I know the scoring system all season did not match the rule.
