Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 16-10-2013, 20:41
ybansal17's Avatar
ybansal17 ybansal17 is offline
FRC #1967 (Janksters)
ybansal17 is an unknown quantity at this point
Lightbulb Battery Carts/Shelves
Our team is remodeling our battery cart.
If anyone has any ideas that can help us out, I'd really appreciate it.
We need to store 10 batteries, 3 individual battery chargers and a triple charger.
The space limitations are 26in x 20in x 20in (height x length x width)
If you have any ideas that can help us out, that would be helpful.
Thanks.
--Team 1967, Janksters
Unread 16-10-2013, 21:54
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: Battery Carts/Shelves
Stack all your batteries on one side, 10 tall with the terminals pointing out. Put the single chargers along the side, with lights visible, and cords accessible within reach of the battery shelf. Put the Triple bay charger on its side and mounted in a similar position. You could use Hook-and-loop fastener (Velcro) to adhere the chargers to a wall.
EDIT: actually looking at your dimensions, you may have to do 2 stacks of 5 batteries, placed back to back, with terminals facing away from each other. The chargers could be on one side of the block to have access to both shelves
Unread 17-10-2013, 11:21
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Rest of your advice is sound, but I wouldn't advise this. I would advise to either screw or bolt your chargers down. Otherwise, with the constant jostling of a competition and transport, they will come loose and cause havoc.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 17-10-2013, 11:27
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You just got to use enough Velcro. Admittedly sometimes screws are easier than enough Velcro.
Unread 17-10-2013, 21:38
yash101 yash101 is offline
AKA: null
The beginning posts of this thread might have some info on what you are looking for
http://www.chiefdelphi.com/forums/sh...d.php?t=118330
Unread 17-10-2013, 21:59
ybansal17's Avatar
Thanks for those suggestions.
It's really helpful.
If anyone has any more ideas, I'm still in the process of designing it.
Thank you.
Unread 19-10-2013, 01:20
AKA: null
Take your time and impress your team
Unread 19-10-2013, 21:43
ybansal17's Avatar
Haha..yep.
I plan to.
Unread 22-10-2013, 17:21
AKA: null
Originally Posted by ybansal17 View Post
Haha..yep.
I plan to.
k. then quit posting and get started
Unread 24-10-2013, 09:10
robowrestler's Avatar
robowrestler robowrestler is offline
AKA: Collin
FRC #3015 (ranger robotics)
robowrestler is an unknown quantity at this point
make sure it is an ergonomical design, so the batteries go in and out efficiently
2016 Pittsburg Regional Chairmans Award Winners
2016 Pittsburg Regional Finalists with 1023 and 4050
2015 Newton Division Finalists with 195,1756,4522
2015 Finger Lakes Regional Winners with 4039and 378
2015 Finger Lakes Regional Engineering Inspirational Award Winners
2014 Finger Lakes Regional Finalists with 340 and 3044
2013 VA Regional Finalists with 2363 and 2053
2012 Finger Lakes Regional Finalists with 340, 4124 and 3044
2012 Buckeye Regional Winners with 340 and 1507
"Kickin Bot Since 2009"
Unread 24-10-2013, 09:57
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Thanks.
We build this last year to transport and house our batteries. It holds 10 batteries, 2 triple chargers, bumpers and is a nice shelf for a tool bin. Transport and storage are all built on to a standard hand truck from Home Depot.
20 deep x 20 wide x 36 tall (not including the hand truck).
Unread 28-10-2013, 14:38
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Thumbs up Re: Battery Carts/Shelves
I don't have a picture of the final project, but we built one for last year's competitons based on similar size constraints and info from here.
Ours is 24"x24"x36" when closed, it folds in half and locks together making a rolling box for travelling; each half is 12"x24"x36" with piano hinge, locking clasps, collapsable handles and caster wheels. It holds 8 batteries standing on edge in slots on the bottom with battery chargers on a shelf above (4 at the bottom of each half). A shelf above for some parts, controllers, etc. Complete with wired power strips so all we have to do is "plug it in" and its going.
The attached image is our "rough draft" before we built it, which doesn't show how we actually built the battery slots and shelves, but you get the idea of folding within itself and locking. One thing we learned, get big enough diameter caster wheels to handle rolling on pavement etc, not all surfaces are smooth floors.
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
Unread 28-10-2013, 20:53
AKA: null
Talking Re: Battery Carts/Shelves
What about pneumatic wheels to absorb some shocks, or if you want to get advanced, an entire suspension system
Unread 29-10-2013, 09:19
TedG's Avatar
Originally Posted by yash101 View Post
What about pneumatic wheels to absorb some shocks...
Pneumatic wheels are not a bad idea, except problems with size constraints.
In our example, the footprint of each half 12"x 24" needing a minimum number of wheels limited the size of wheels/base plates that could fit. The bigger the wheels, the further away from the edges the wheels would be. We needed to make sure wheels would be at all 4 corners when closed for rolling when travelling, and enough wheels on the inside edges when opened so it was sturdy.
We went with 8 swivel caster wheels with the 4 outside being "lockable" so when opened up in the pits we could lock the wheels and it stayed opened and didn't move.
Unread 29-10-2013, 09:24
AKA: Rees
We chose a handtruck that had pneumatic wheels for this exact purpose.
