Go to Post The robotics, strategics, and technology make up the higher wavelengths, the adrenaline of competition the midband, and the low frequencies that pull at the heart, well that's the people. - John Wanninger [more]
Unread 17-10-2013, 22:18
Re: Striving to learn more with Programming!
I'm not sure I understand how you expect this to work, but if you post questions or challenges that you are having difficulties with, myself and many others will be happy to help.
Greg McKaskle
Unread 18-10-2013, 11:58
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
I'm also a little unsure what the intent of this thread is. Are you asking that we teach you new techniques, or are you suggesting that we create compendium of programming tips for programmers less experienced than yourself?
Originally Posted by Team3763 Adam View Post
Entering my fourth year on a Robotics Team, and being my third year programming
What I want to do is learn how perform some of these functions, not just your standard Drive, shooter, and basic Autonomous codings.
What do you consider "basic" autonomous routines? Have you successfully implemented complete autonomous routines for the last 3 years of FIRST games? If not, that would be a great place to start, especially since you're already given example code as part of the LabVIEW distributions. Try to understand that example code, then write it again from scratch, perhaps adding any improvements you've thought of in the process. Hopefully your team has a programming "mule" robot that you can use to try out the routines.
If/when you've gone through this, check back and I'm sure we can help you brainstorm some more ideas for projects.
If you want something that's more directly usable in the future, try coding a waypoint autonomous framework. It should work something like as follows: Accept a list of (x, y, angle) coordinates, where (0, 0, 0) is the center of the field, facing away from your team's driver station. The first coordinate represents the starting position of the robot. The robot should then calculate the necessary movement to reach the next waypoint's coordinates, and drive their using gyro and encoder feedback. Then, when you get the game, you can quickly try out autonomous routines by simply inputting lists of coordinates. Wildstang (111) had it working in 2003 (video is reposted on YouTube with 111's permission).
Then someone who is rather new, unlike myself, would try to challenge themselves and see if they can truly figure out how to work the camera through this website, the tutorials on LabVIEW and other means of finding out.
Why don't you start us out? Post up an example tutorial for some technique that you've already learned and found helpful, so we know what you're intending with this thread.
FRC 766, 2015-, Mentor
Unread 21-10-2013, 01:05
Originally Posted by RyanCahoon View Post
Wildstang (111) had it working in 2003 (video is reposted on YouTube with 111's permission)..
The presentation gives very helpful insight into how StangPS works. There are some small math errors which may confuse some students viewing it. Worth discussing?
Unread 23-10-2013, 00:11
RyanCahoon's Avatar
Worth discussing?
Perhaps. (I'm surprised it's not been brought up before; that video's been around for a while.) Is there one of your follower-wheel odometry posts that would be applicable?
Unread 23-10-2013, 09:10
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
If you are just interested in learning more about how to use LabVIEW to program your robot, including image processing, you could try this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=120756
Unread 23-10-2013, 09:43
:-) ... OK. Lets' do it that way.
Question1: In the video, is the positive X axis pointing to the left or to the right?
Last edited by Ether : 23-10-2013 at 10:36. Reason: added link to video for convenience
Unread 27-10-2013, 01:19
RyanCahoon's Avatar
Judging by the coordinate values given in the second half of the video, I would say the positive X axis is to the right, positive Y axis is up.
I think I see where you're going with this though... in that the diagram showing angle theta as an acute angle doesn't match the angle that would be calculated from delta-x and delta-y in the world coordinate system.
So to answer your original question, I think at this point it's probably just worth noting that the video is meant to give an intuitive sense of how things work and the general types of formulae that will be needed instead of being mathematically rigorous.
My request for one of your odometry posts was meant to ask whether you already had a post somewhere that gave the correct mathematics, as it seems like something you might have covered before.
Unread 27-10-2013, 10:36
Yes. As I said in post 5, the presentation gives very helpful insight into how StangPS works.
Aaron.Graeve did an admirable job of explaining the math in this thread. If anyone wants to explore this further, that would be a better thread to discuss it, so as not to hijack this thread.
