Go to Post That's is why I raised this question, becuase I do not know all the facts (I doubt anyone does). - Ken Leung [more]
Unread 20-10-2013, 00:04
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Common or uncommon sensors used in FRC
Garage door sensors are the IR beams used to detect if something (like a child) is in the way of your garage door as it descends. The sensor is actually a pair of devices: an IR emitter and an IR receiver. The receiver sends a different signal when it can and cannot see the emitter beam. We have used them for a variety of purposes. Taking Rebound Rumble as an example, we had a garage door sensor mounted low in the robot. When we started picking up a ball it would block the beam and the sensor would signal that something (a ball) was blocking its beam. When the ball cleared the beam and the receiver could again see the emitter the robot knew to turn off the conveyor. A similar set up at the top was used to "count" balls going to the shooter. Together these two garage door sensors let us move balls efficiently inside the robot and count the balls we picked up and shot.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
