Go to Post ANY team is capable of producing a winning design. This does NOT require anything more than brainpower, and time. - Racer26 [more]
Unread 23-09-2013, 06:46
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Generating preverified jars
Something I've been toying with is using microlog to take care of our logging needs (replacing System.out.println). I have had good success integrating microlog into a robot if I include (stripped-down) source code, but now I want keep microlog as a separate jar and include that jar into the robot build.
Does anyone have an example of a build.xml to generate a preverified jar, ready to include in a Robot?
Unread 20-10-2013, 11:10
Spaghetti's Avatar
Spaghetti Spaghetti is offline
FRC #0488 (XBot)
Spaghetti is an unknown quantity at this point
Re: Generating preverified jars
Hey there, we recently had the exact same problem with shared jars. What we ended up doing was copying the build.xml from the wpilib project (which builds a pre-verified library .jar) and then run the target 'dist'.
Would be interested in your results with using microlog if you get it going. We've been rolling our own logging solution from scratch each year.
Unread 20-10-2013, 21:10
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
I'm not so much interested in the logging part, but want to know how exactly you can include other jars when building. If someone figures it out, can you post specifics of how to do it?
All opinions are my own.
Unread 20-10-2013, 22:09
alexhenning alexhenning is offline
WPILib Developer
FRC #0348
alexhenning will become famous soon enough
If you look in the ~/sunspotfrcsdk directory, you can see how team's code is preverified.
Specifically, looking at ~/sunspotfrcsdk/build.xml and ~/sunspotfrcsdk/ant/preverify.jar will show you how to preverify with ant. Once you've preverified it, you can look into adding to the classpath in ~/sunspotfrcsdk/ant/classpath.xml. Unfortunately, the process of adding libraries isn't straightforward.
Hopefully this helps get you started.
Unread 28-12-2013, 19:00
Spaghetti's Avatar
FRC #0488 (XBot)
We'll try to post up our off-season code soon and I'll put a link here. It'll have an end-to-end example of a separate project .jar getting pre-verified and included in a robot project.
Unread 02-01-2014, 16:24
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
Following up on Spaghetti:
https://github.com/Team488/Shared
There are 3 projects in there:
-Core
-Test
-ActualRobot
Core gets preverified so it can be included in ActualRobot.
