Go to Post There are times when your team will struggle and there are times when it will achieve great victories. There will be times when unknown and uncontrollable factors will intercede to provide an unexpected outcome for which your team must compensate. - Travis Hoffman [more]
Unread 23-05-2013, 15:33
Halo_Kid_3633's Avatar
Halo_Kid_3633 Halo_Kid_3633 is offline
FRC #3633 (Catayst)
Halo_Kid_3633 is an unknown quantity at this point
Is this Programmable with C++?
My team loves to make programmers have nightmares and really want to use this to control our robot, but I dont know if it possible.
Team 3633
Unread 23-05-2013, 20:26
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Is this Programmable with C++?
Possible? ANYthing is possible.
Practical, worthwhile, interesting... THOSE are the questions to ask.
Unread 23-05-2013, 21:53
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
It's a modified arduino. Use this http://www.team221.com/robotopen/
It's exactly the same but with a nice safe communication protocol written for you.
2016: FRC 865 Mentor
Unread 26-05-2013, 17:18
FRC #3633 (Catayst)
well is it
Unread 26-05-2013, 17:22
FRC #3633 (Catayst)
No its not this would go into the computer.
Unread 26-05-2013, 17:27
mman1506's Avatar
no team (WARP7)
Yes it is. Check out the schematic http://dlnmh9ip6v2uc.cloudfront.net/..._makey-v12.pdf and the github https://github.com/sparkfun/makeymakey
It is programmed with the arduino IDE and is an arduino derivative.
Unread 31-05-2013, 12:33
FRC #3633 (Catayst)
So I've been looking at this some more and the thing holding me up from getting this is, does the Driver Station recognize the Makey Makey as a Joystick or not, and if it doesn't is it possible to modify if to recognize as a Joystick?
Unread 24-07-2013, 10:43
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
The Makey Makey is an Arduino (Arduino Sketch editor is C++ code) that connects by USB to a host and is recognized as a keyboard or mouse.
This should help you out: https://www.sparkfun.com/tutorials/378
If you want to get a joystick, you'd need access to the analog input (pins A0 to A5 are analog) of the Atmel chip on the MaKey MaKey and follow something like this: http://www.arduino.cc/en/Tutorial/JoyStick.
Unread 21-10-2013, 09:56
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
The MakeyMakey talks to the computer as if it were a keyboard and mouse. So getting it to interface with the Driver Station would require either an additional third party program, such as AutoHotKey, or reprogramming the MakeyMakey's built-in arduino. See http://www.makeymakey.com/forums/index.php?topic=5630.0 for an idea of how to get started with stuff like that.
Proud alum of CORE 2062.
www.core2062.com
Unread 21-10-2013, 11:13
It's possible to program the Dashboard to recognize keypresses on the computer running the Driver Station program, and to communicate to the robot based on the keys pressed. You can use a custom UDP communication scheme, or put the desired information in a Network Tables variable and let the provided framework move the data from place to place.
Unread 29-10-2013, 08:21
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
What do you mean? You can you a arduino to interface with a laptop computer. I say this because the Arduino is a computer too just not very powerful. But anyways Arduino is much better than a laptop at reading raw sensor data with it's raw I/O pin ports. What you can do is program the Arduino to detect a input then interface the arduino with the laptop through USB and using serial communication, then having a program on the computer that can read the Arduino's serial data then perform a programmed action on the computer.
I hope you know what I mean.
Unread 05-11-2013, 11:31
FRC #3633 (Catayst)
Originally Posted by Alan Anderson View Post
It's possible to program the Dashboard to recognize keypresses.
How do I go about doing this?
haha
- Yup Me
Unread 05-11-2013, 14:50
It's possible to program the Dashboard to recognize keypresses...
The relevant functions are in the Connectivity -> Input Device Control subpalette. Use the Initialize Keyboard vi to create a reference to the computer's keyboard. Pass that reference to the Acquire Input Data vi. The output of the Acquire will be an array containing all the keys that are currently pressed.
If you want to test for a specific key, you can feed the "keys pressed" array into a For Loop using auto-indexing. Each iteration of the loop will get one of the keys in the array. You can compare the detected key against a constant representing the key you are looking for.
