Go to Post And remember, it's the fall semester. So FIRST isn't an excuse for a failing grade (not that it's ever an excuse)! - Billfred [more]
Unread 17-10-2013, 22:18
adlasa's Avatar
adlasa adlasa is offline
President and Lead Programmer
AKA: Sasha
FRC #1458 (Red Ties)
adlasa has a spectacular aura aboutadlasa has a spectacular aura aboutadlasa has a spectacular aura about
Same initialization as declaration in constructor, why?
I was looking through the basic tutorial on C++ with an FRC robot.
The code:
public:
   RobotDemo(void):
      myRobot(1,2),
      stick(1)
The comments say these declarations have to be initialized in the same order as they are declared.
Why is this?
Computers run on smoke. When the smoke escapes the computers stop working.
Unread 19-10-2013, 11:56
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Same initialization as declaration in constructor, why?
I don't know of anything in the C++ standard that requires the member initialization list to be in declaration order. It might be some limitation of the compiler, or they might be encouraging that for code readability because the C++ standard does say that no matter the order in the initialization list, the class members will be initialized in the order they are declared in the class definition.
I don't have windriver installed so I can't check to be sure which it might be, but there's nothing keeping you from trying it out. What happens if you reverse the initializers in the example code and try to compile it?
FRC 766, 2015-, Mentor
Unread 21-10-2013, 10:00
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Its not a requirement, but strongly recommended, as giving them a different order will lead to very unintuitive behavior, as well as a warning from GCC. As Ryan said, no matter what you put in the initialization list, the members'll be initialized in the order they are declared up above.
Proud alum of CORE 2062.
www.core2062.com
Unread 24-10-2013, 00:38
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
The reason for this is that if you want to declare a member variable as some transformation of another member variable, you can end up with declaring it before the first variable is initialized. So, if you have:
class Example {
private:
    int a;
    int b;
public:
    Example();
Example::Example():
    b(2), a(b+1) {
the value of a will not be 3, but undefined, even though it looks like it's declared after b. It's not a compiler error to have them in a different order, but it will produce a warning (I believe the warning is "warning: when initialized here").
