Go to Post P.S. - Don't eat spicy food before a match, or a marathon of matches like eliminations. It never ends well. Trust me. - Keith Chester [more]
Unread 21-10-2013, 13:13
ftcTeam6389 ftcTeam6389 is offline
FTC #6389
ftcTeam6389 is on a distinguished road
[FTC]: Using VEX omni-wheels with Tetrix motors ??
Has anyone successfully mounted VEX omniwheels like these (http://www.vexrobotics.com/vexpro/wh...ni-wheels.html) onto Tetrix DC motors? If so, can you share what you needed to do to make it work? Or does it work out of the box?
thanks
FTC Team 6389
Unread 21-10-2013, 14:36
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: [FTC]: Using VEX omni-wheels with Tetrix motors ??
thanks
FTC Team 6389
It does not work out of the box. The Tetrix motor output is a 6mm diameter shaft with a flat on it for a set screw (D-shaft). The regular Tetrix axles are 4.7mm diameter. The omni wheels you link to require the VexPro VersaHubs (http://www.vexrobotics.com/versahubs.html) to interface with any kind of shaft, but these are illegal per the FTC rules because they are non-Tetrix hubs. If you want to use the wheels, you'll have to find a way to manufacture your own hubs from raw stock that go from the VersaKey pattern to the 6mm motor shaft, the 4.7mm axle shaft, or the bolt pattern used by the Tetrix gears/sprockets/hubs so you can attach it to a Tetrix hub.
Unread 22-10-2013, 12:07
FTC #6389
Thank you for your reply. FTC has recently amended the rules to allow the compatible hubs. See the official post at http://ftcforum.usfirst.org/showthre...ull=1#post7546
- FTC Team 6389
