Go to Post I respect what you have to say and I ask that you do the same for me. - Andrew Schreiber [more]
Unread 21-10-2013, 21:29
klui17 klui17 is offline
klui17 is an unknown quantity at this point
Re: [FTC]: Samantha connected, but not working
NOOOOO do NOT enter the password in the FCS. We accidentally did this in the configuration window and had to completely re-download the FCS to get the original password back. Make sure that the samantha.hex file is on the Flash Usb drive that you created and make sure that it is the one that came with your FCS. also, when flashing the samantha, make sure that two complete light cycles happen, then unplug the usb drive BEFORE powering the samantha off. When pressing the red button to pair the FCS with the samantha, press connect, then one short click of the red button is all that is needed. last, make sure that the program you are running is using the FCS competition toolkit (if made in labview). Hope this helps!
Unread 27-10-2013, 19:58
SentryMaster SentryMaster is offline
SentryMaster is just really niceSentryMaster is just really niceSentryMaster is just really niceSentryMaster is just really nice
Thanks for all the help! It turns out that the wireless on my router was 11mbps and it should have been 2mbps. I now have another router that connects to the Samantha and works fine. Thanks again
Unread 28-10-2013, 13:55
FTC5096 FTC5096 is offline
AKA: Kim Daugherty
FTC #5096 (Monkey Madness)
FTC5096 is an unknown quantity at this point
Do you have documentation on other router wireless settings such as the 2 mbps that affect Samantha? I didn't see anything in the documentation at usfirst except for wireless-b and the recommendation to use WPA2 personal.
