Go to Post Not all creativity is visible or mechanical! - dtengineering [more]
Unread 21-10-2013, 21:55
yash101 yash101 is offline
AKA: null
Lightbulb Re: 233 telescoping arms how do they work?
Maybe fill it up with pressurized air (like a piston out) to make it longer, and have a spring retract it. Maybe that will work for light/medium loads
Unread 21-10-2013, 22:12
Jared's Avatar
Jared Jared is offline
If you could get the thing air tight (which would be really tough) I don't think it would be legal per the 2013 rules. I know a team wanted to fill a balloon with air from the compressor, but they weren't allowed to.
Unread 21-10-2013, 22:14
EricH EricH is online now
Except that if you don't do that with a COTS pneumatic cylinder, you're in violation of the rules (specifically R76). I don't see the ban on non-COTS pneumatic items going away anytime within the next decade, if not century. On top of the large volume of air you'd need for any reasonable extension length, and the fun of fitting at least one cylinder that long inside the arm, which make for a very nasty engineering challenge between them...
Unread 22-10-2013, 00:45
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Am I the only one that likes the lead screw method?
Its beautiful.
If you ask, they're more then happy to share some drawings on that arm. I have them saved somewhere. To me, it seems a little more simple and solid then all these chain runs. Cons being I'm not sure how you'd have multiple stages.
Unread 22-10-2013, 01:22
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Its beautiful.
Very cool! I love the robot, I'm really surprised not to have heard of it before.
I suppose another disadvantage of the leadscrew would be it's expense and inefficiency. Of course, it does look like a very elegant solution in that situation.
-Plutarch
Unread 22-10-2013, 19:15
Jared's Avatar
Its beautiful.
If you use lead screws right, they are a really solid and durable solution, but may be overkill for some applications. This year, our climber used two lead screws, and although it was heavy, we never had a single mechanical problem with the lead screws, which was the only part of any robot we've ever built that was this reliable. We fell off of the top of the pyramid, and from the second level, and our climbing device wasn't damaged at all.
Unread 28-10-2013, 04:19
FRC #1836 (MilkenKnights)
Stuff got moved around in my google drive, and the previous album link now does not work. I got a PM to repost the link so here it is: https://drive.google.com/folderview?...&usp=sha ring
I will have to try to find a more permanent solution for the future.
