Go to Post Teamwork gracious professionalism robots = FIRST Robotics - Bcahn836 [more]
  #31   Spotlight this post!
Unread 21-10-2013, 21:51
yash101 yash101 is offline
AKA: null
Talking Re: LiFePO4 Batteries
Darn It! Typo. 14,000. Let me edit the post above
  #32   Spotlight this post!
Unread 21-10-2013, 22:13
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Originally Posted by yash101 View Post
Anyways, does anyone know where I could buy a car motor?
go to a "u pull it"
find a prius
extract motor?
http://www.cloudelectric.com/product...em200-d135.htm
this would be the motor to use if you are doing what i think you are doing.
My Instructables
  #33   Spotlight this post!
Unread 22-10-2013, 00:06
AKA: null
That seems like a legit motor. Also, is it advisable for me to use two motors, one controlling each side of the car? If so, that would allow easier computer control of the car. Also, I am planning to implement an autopilot routine, (in the future years), to just follow the roads straight and automatically stop and start in traffic jams. The following will probably use a camera and the stopping will be done either with a ping or a laser rangefinder.
  #34   Spotlight this post!
Unread 26-10-2013, 18:20
AKA: null
Exclamation Re: LiFePO4 Batteries
Hey, can someone post about how safe/unsafe these batteries are against AGM/FLA/VRLA (Lead Acid) bateries? I do not want this car that I am building be a bomb in ceratin cases!
  #35   Spotlight this post!
Unread 26-10-2013, 18:25
AKA: null
I don't know of any motors myself. However, I will again point you to the SAE Clean Snowmobile Challenge, which has a zero-emissions category (AKA electric). They're building for range, power, and lack of emissions--and I bet they know some good motors if you're able to contact one of the teams. There might even be one near you.
Living in the middle of Arizona, a desert, I am probably unlikely to find Snowmobile Designers?
  #36   Spotlight this post!
Unread 26-10-2013, 19:44
You can find them in some unlikely places (though I admit that I don't see any registered teams from anywhere south of Illinois). And remember, there's this wonderful invention called the Internet, which can help you connect with folks who actually have winter. (As a matter of fact, I remember having a couple of folks from Arizona on my Aero team--which worked in the same room as the Snowmobile team--during my final year of college in South Dakota, one of whom may have graduated from your FRC team--I can never keep 1164 and 1165 straight.)
As far as safety, AFAIK, they're pretty comparable as long as you don't do anything utterly stupid. The risk of flammability is a bit higher, but not nearly as bad as LiPOs. If you're shipping them, you have to have someone who's registered to do that, though I don't think that'll be too big of an issue if you're not shipping them. Charging is more of common sense--use the right charger, and make sure it stops when it needs to.
  #37   Spotlight this post!
Unread 26-10-2013, 22:43
philso philso is offline
FRC #2587
There are quite a few people out there who have been building electric cars for a long time. Many of them are members of the EAA (I gave you the link in my first post in this thread). You are best to start by getting in touch with a bunch of them in your area.
  #38   Spotlight this post!
Unread 27-10-2013, 13:49
how big is this car? are we talking go kart size or like a actual car size.
assuming you construct the pack correctly, as long as you don't draw more amps than the cells "c" rating or discharge the cells below 2.8v you shouldn't have problems.
My Instructables
  #39   Spotlight this post!
Unread 27-10-2013, 16:59
AKA: null
I am thinking a little bigger than a a go-kart, but way smaller than a regular cart. that is the project, basically. that way, the car will be small enough to drive even inside a building !
  #40   Spotlight this post!
Unread 28-10-2013, 12:11
AKA: null
Hey, before, I was looking at Howell batteries because of their price. After doing a couple hours more of research, I came upon Winston Batteries (LiFeYPO4 instead of LiFePO4). Does anyone have experience with these batteries or this manufacturer?
Also, where can I buy these for the best possible price?
