Go to Post "Programming is 1% talent and 99% not getting distracted by the Internet." - FRC4ME [more]
Unread 23-10-2013, 19:01
asmsresearch asmsresearch is offline
FRC #3469
asmsresearch is an unknown quantity at this point
[FTC]: robot C to labview
What is the best way to take Robot C formatted NXT bricks anf format them for LabView?
Unread 26-10-2013, 18:20
bbsmith24 bbsmith24 is offline
FRC #0503
bbsmith24 is an unknown quantity at this point
When you try connect the NXT with RobotC to LABView, you'll get a message about reloading the firmware. Do that and your NXT will work with LABView
Brian Smith
Coach
FTC#5341 Black Frog Robotics
Unread 27-10-2013, 16:08
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: [FTC]: robot C to labview
When we've tried to do that, LabView simply doesn't recognize the Robot C NXT. When that happens we've installed the firmware from the Lego, then imaged it with LabView. It'll recognize it if it has a Lego image.
