Go to Post We need to grow smart not grow fast. - Andrew Schreiber [more]
Unread 22-10-2013, 17:07
scuba1000 scuba1000 is offline
AKA: Jack Breen
FRC #1661 (The Griffitrons)
scuba1000 is an unknown quantity at this point
Designing a Planetary Gearbox to increase speed?
I have been researching ways to design a planetary gearbox. It seems that the main configuration of the gears is to have the ring gear fixed, output the rotation of the planet gear carrier, and use the sun gear as the input. This would produce a reduction.
I have found little information about using a planetary gearbox the other way around to multiply speed. Is it commonly done or is there some other alternative to this? The design would be to have the ring fixed, the gear carrier as the input, and the sun as the output. Is the ratio just the reciprocal of the normal ratio.
I did see that the Wikipedia article on planetary gearboxes said that the ratio for what I'm talking about is 1+ Nring/Nsun. But it said a citation is needed, so I just wanted to double check.
Unread 22-10-2013, 17:17
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Re: Designing a Planetary Gearbox to increase speed?
The most common example is an old-school pencil sharpener (although maybe not as common anymore). The handle is attached to the carrier and the planets spin relatively fast compared to the crank handle, which causes several rotations of the sharpening cylinders around the pencil. There is no sun gear in this case, as the desired output is shearing of pencil pieces, rather than shaft output speed.
Yes, the ratio with a fixed ring gear with the sun as the output is 1 : (1+Nring/Nsun). You can do any of the 6 combinations of sun, carrier, or ring fixed with the other 2 being input and output. The math gets kinda fun, and I'm sure I could dig up an old textbook to cite. Certain configurations even produce backwards rotation.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 22-10-2013, 17:46
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Ns * Ss + Nr * Sr = (Ns+Nr) * Sc
where N is number of teeth and S is speed, s, r, and c are sun, ring, and carrier.
If the speed of the Ring (Sr) is zero then:
Ns * Ss = (Ns + Nr) * Sc
or
Sc= Ns / (Ns + Nr) * Ss
(This is for a simple planetary)
Unread 22-10-2013, 17:53
AKA: Jack Breen
Excellent. Thank you both.
Unread 22-10-2013, 18:12
IKE's Avatar
IKE IKE is online now
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
or
As Tom is showing, technically, all 3 can spin at a given rate. One of the more recent and famous versions of this is the drivetrain of a Prius:
http://en.wikipedia.org/wiki/Hybrid_Synergy_Drive
In your scenario, you are used to seeing a PSR or Planetary speed reducer. This is usually because you have a high speed source (like an electric motor) and want high torque to do some useful work.
Windmills are the opposite and have PSI or planetary speed increasers as they blades produce a lot of torque, but the generator wants higher speeds.
Unread 22-10-2013, 21:24
DonRotolo's Avatar
Back to humble
FRC #0832
While it can be done, in FRC it usually isn't, because our motors are generally too fast and we need to slow the speed down (without losing power). All the info above is good.
Unread 23-10-2013, 07:49
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
To increase speed, you need to drive the carrier (with a stationary ring). The Sun gear would be output. This is the opposite of the normal FRC arrangement.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 23-10-2013, 09:21
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
If you want to play with one to see how they work, look for the Tamiya Miniature Planetary Gearbox Kit with Motor. They are about $20 and come with 4 sections to give you multiple reductions / increases.
(General plug, Tamiya makes a series of motor/gears/transmissions/etc. that are easy to assemble and watch how they work. )
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 23-10-2013, 12:19
President, VEX Robotics, Inc.
If you want to learn more than you ever wanted to know about multiple moving parts of a planetary transmission, please look here: http://www.chiefdelphi.com/media/papers/1361
We did this in our 2002 robot and never got it working like we wanted until Championship. It worked like a charm then.
This was the very first year the CIM motor was introduced.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 23-10-2013, 20:45
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
From Wikipedia
Originally Posted by Wikipedia
This limited gear-ratio set, forces the engine crankshaft to rotate at speeds where the ICE is less efficient, i.e. where a liter of fuel produces less joules.
Does this make sense? Does a limited gear-ratio set on a ICE produce incomplete combustion?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 23-10-2013, 20:58
DonRotolo's Avatar
Back to humble
FRC #0832
I did not check the article, but it is a fact that certain IC engine speeds are more efficient than others. Depends on the engine of course but efficiency generally peaks around 2500-3000 RPM. If you put a stupid gear ratio in you can force efficiency down.
Unread 23-10-2013, 21:03
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You can force efficiency down, but does a litre of fuel produce less joules as stated? I assume this is only possible due to incomplete comubstion?
Kevin Li
596 - Sciclones
Unread 23-10-2013, 22:00
No. It produces fewer joules.
The joules being referred to are mechanical output joules at the engine crankshaft, not joules of combustion heat.
Unread 23-10-2013, 23:58
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I'd presume that fewer joules of the chemical are released at all--IE some of those joules are turned into entropy.
-Plutarch
Unread 24-10-2013, 09:58
For a given required mechanical power output at the engine crankshaft, there is a continuum of engine_speed + fuel_flow_rate combinations which will produce that power. Only one of those pairs minimizes the fuel_flow_rate.
