Go to Post Sounds like a silly idea... so of course I'm in. - George1902 [more]
Unread 25-10-2013, 01:56
lukedude43 lukedude43 is offline
Doer of stuff and things
AKA: Luke Reinert
FRC #4030 (NullPointerException)
lukedude43 will become famous soon enoughlukedude43 will become famous soon enough
Telescoping arm bearing block help
Hey, lately I've been looking into telescoping arms and I am pretty confident in my understanding of there mechanics, but the one thing I just don't understand are the bearing blocks inside. If there was any way I could get pictures or drawings of some teams bearing blocks I think I could figure it out.
thanks in advance
Unread 25-10-2013, 07:52
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: Telescoping arm bearing block help
I'm not sure I understand you. Are you talking about linear bearings like this that allow linear movement through the bearing? Or are you talking about the bearings for pulleys on a cable-driven telescope? Most of the time, when our team refers to "bearing blocks", it's regarding a piece of metal or plastic that holds a bearing in place, usually on the side of a wheel or other driven implement opposite the motor. Can you please add some more details?
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 25-10-2013, 21:13
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
This thread should help you out a lot:
http://www.chiefdelphi.com/forums/sh...light=233+arms
Unread 26-10-2013, 04:14
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
I think he is referring to the bearing blocks used to the guide the inner and outer tubes in the arm.
https://fbcdn-sphotos-c-a.akamaihd.n..._5274788_o.jpg
This is the bearing block system from 604's first arm in 2011, which was 3" square outside tubing and 1.5" square inside tubing. The left block inside the top of the outer tubing and the right block inside the bottom of the inside tubing. The bearing system worked great, but even with the large block split into four pieces, there was a lot of machining in those blocks. We redid the arm with much smaller tubing as an off-season project later with delrin slides. It was far lighter, but did have a noticeable amount of friction. However, the machine time was next to nothing, even on a benchtop cnc.
Hopefully this is what you are looking for
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 26-10-2013, 13:21
AKA: Luke Reinert
Yea that's exactly what I was referring to that makes perfect sense, thanks
