| Thread Tools |
Rating:
Display Modes |
#16
Re: Pneumatic Test Stand
Thanks once again for the safety tip! |
#17
- I have added a separate power supply for the pump: the "on board" one powers the relays and instrumentation - Per above suggestions, an pressure switch drives an automotive relay to cycle the pump To do: -The "air production module" is now complete. I will put a Lexan screen over the plastic tanks per the above safety discussion. -I am now working on the "test bench" module. This is where you can quickly lash up different mechanisms and try them out. - I need some sort of "tinker toy" parts quick to assemble arms, gears, cams, grippers, levers, etc. - I need to have alternate inputs to allow solenoid actuation from the robot cRIO - My son (in Electrical Engineering program) is developing a data analysis systemm with pressure and position transducers, force load cells, and a PC-based data recording system so we can quantify performance and compare designs. If anyone has good ideas or would like to team up, please let me know! Last edited by Avrum Goldman : 27-10-2013 at 14:19. Reason: Add photo |
