Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 29-10-2013, 17:21
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Re: Calculating Linear Force from Motor Torque?
Gotcha, thanks so much!
Just a quick question.
Right now we have it set up such that the motor has an 80 tooth gear, turning a 40 tooth gear, which is on the same axle as a rack and pinion gear (32 tooth I believe).
I feel like the calculation is a bit different in this case.
My assumption is that I can say the motor torque "doubles" from the gear ratio, lending to a 283 * 2 oz-in torque on the axle w/ the 40 tooth and pinion gear.
At this point, do I use the radius of the pinion gear to determine linear force on the rack and pinion?
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
