Go to Post Al's Murphy's law corollary...If it can go wrong, it will on Einstein - Al Skierkiewicz [more]
Unread 28-10-2013, 10:44
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
How does the Driver Station fiddle the network settings?
We wrote a script last year that uses netsh to fix up our network configuration when it gets hosed (our development PCs have two NICs, one to the school network, one dedicated for robots). We have the fun wrinkle that our school is using 10.x.x.x, so when the Driver's Station changes the network mask for the robot NIC to 255.0.0.0, we lose Internet.
We are getting school PCs moved over to Windows 7, and we can no longer use the "netsh" command to fix up addresses and network masks (unless run as administrator).
The Driver Station is able to fiddle with the network settings on W7: how does it do that? We need to emulate it....
Unread 28-10-2013, 15:13
Re: How does the Driver Station fiddle the network settings?
It is allowed to do so because it is signed and has a manifest that gives it admin privileges. My search results indicate that runas may allow you to do the equivalent things as sudo to your script.
Good luck.
Greg McKaskle
Unread 28-10-2013, 18:11
FIRSTgenius FIRSTgenius is offline
FRC #3318
FIRSTgenius is an unknown quantity at this point
fovea1959, can you provide a link to the script? This would be so helpful for our team.
Thank you.
Unread 28-10-2013, 18:12
FRC #3318
Can you provide the link to the script?
Unread 28-10-2013, 19:05
A few people have provided scripts or tools:
http://www.chiefdelphi.com/forums/sh...ighlight=netsh
Unread 31-10-2013, 18:56
fovea1959's Avatar
AKA: Doug Wegscheid
Joe, once again, thanks.
All: Joe's information is what we've worked off of.
Unread 31-10-2013, 19:22
fovea1959's Avatar
AKA: Doug Wegscheid
...and Greg, thanks for the answer!
